What's the difference between these 2
Old Oct 19, 2017 | 08:58 AM
chuck1022's Avatar
chuck1022
Default What's the difference between these 2
Arizona
http://www.lexus.com/lcertified/search-inventory?vin=2T2ZK1BA2FC161067.
California
http://www.lexus.com/lcertified/search-inventory?vin=2T2ZK1BAXFC204067.
what level rx350 has Mark Levinson?
Old Oct 19, 2017 | 09:04 AM
chuck1022's Avatar
chuck1022
For some reason i cant make the links hot from my phone
Old Oct 20, 2017 | 12:42 PM
Skier76's Avatar
Skier76
Originally Posted by chuck1022
I think the period at the end was causing the issue. Should work now.
Old Oct 20, 2017 | 03:50 PM
JDR76's Avatar
JDR76
From a quick look, the only real difference I see is that the more expensive one has the sport appearance package. ML is a stand alone option.
These pictures make me miss our RX. What a great vehicle that was.
Old Oct 20, 2017 | 03:55 PM
Prince101's Avatar
Prince101
They seem like the same car honestly with just one having like 3000 more miles maybe one has more features then the other making it a bit more expensive...?
Old Oct 22, 2017 | 04:13 AM
Freds430's Avatar
Freds430
IMO great combo. Wife has this exact color combo in a 2015 RX450. Checking on Lexus.com for prior service this is what was showing. The first one in AZ has had all the maintenance done on schedule. At 24,000 miles the battery was replaced. Also at the same time they replaced the drivers bottom seat cushion. Previous owner stated it was wrinkled. Done on goodwill and was not covered by warranty. I would check it over carefully and also the passenger side. Did not showed tires being replaced and could have been done somewhere else. If tires have not been replaced will need it soon at a cost of around $900.
The second one in CA had the tires replaced at 26,000 miles and at the same time a new battery. All the maintenance has been done except the 20,000 mile. This basically is a oil change and could have been done somewhere else.
Which ever you get would highly recommend Weathertech's all weather brown mats. Looks great with accents and carpet. Would also replace all the interior bulbs with LED's. There are post here on what size and how to do. Makes a world of difference.
Old Oct 22, 2017 | 08:23 AM
lexusrus's Avatar
lexusrus
Yes, get the best:. Weathertech's all weather floor mats.
I'm a very happy and satisfied customer!!!
Old Oct 24, 2017 | 11:54 AM
chuck1022's Avatar
chuck1022
Default 2015 Lexus RX350 Service history
26825 MILES
DATE: 09/11/2017
REPAIR# 0082143
REPORTED BY: Lexus of Glendale
SERVICE: CERTIFIED PRE-OWNED INSPECTION PERFORMED
DESCRIPTION: CERTIFIED PRE-OWNED INSPECTION PERFORMED ~ ~PERFORM 161-POINT CERTIFIED PRE-OWNED INSPECTION ~ ~ ~ ~CERTIFIED PRE-OWNED INSPECTION PERFORMED
SERVICE: DETAIL PERFORMED & INSTALL PLATES & FRAMES
DESCRIPTION: DETAIL PERFORMED & INSTALL PLATES & FRAMES ~ ~PRE-OWNED LEXUS DETAIL & INSTALL FRAMES / PLATES ~ ~ ~ ~DETAIL PERFORMED & INSTALL PLATES & FRAMES
SERVICE: PERFORMED 25,000 MILE SERVICE INTERVAL OR 30 MONTH INTERVAL REPLACED AIR FILT
DESCRIPTION: PERFORMED 25,000 MILE SERVICE INTERVAL OR 30 MONTH INTERVAL REPLACED AIR FILT ~ ~PERFORM OIL AND FILTER CHANGE, TIRE ROTATION ~ ~ ~ ~PERFORMED 25,000 MILE SERVICE INTERVAL OR 30 MONTH INTERVAL REPLACED AIR FILTER REPLACED A/C FILTER REPLACED OIL AND FILTER REPLACED WIPERS
SERVICE: REPLACE FOUR TIRES. MOUNT AND BALANCE + REPLACE TIRE WEIGHTS
DESCRIPTION: REPLACE FOUR TIRES. MOUNT AND BALANCE + REPLACE TIRE WEIGHTS ~ ~REPLACE FOUR TIRES. INCLUDES MOUNT AND BALANCE + REPLACE TIRE WEIGHTS ~ ~ ~ ~REPLACE FOUR TIRES. MOUNT AND BALANCE + REPLACE TIRE WEIGHTS
SERVICE: REPLACED BATTERY FGX2-G0EH8-KJNCJ
DESCRIPTION: REPLACED BATTERY FGX2-G0EH8-KJNCJ ~ ~UPON INSPECTION FOUND BATTERY FAILING TEST ~ ~FOUND BATTERY FAILING TEST ~ ~REPLACED BATTERY FGX2-G0EH8-KJNCJ
16855 MILES
DATE: 12/31/2016
REPAIR# 0080131
REPORTED BY: Lexus of Thousand Oaks
SERVICE:
DESCRIPTION: REMOVE TIRES, INSPECT AND MEASURE BRAKE ROTORS AND PADS, INSTALL TIRES IN ROTATED POSITION AS APPR
SERVICE: ADD WASHER SOLVENT AS NEEDED
DESCRIPTION:
SERVICE: INSPECT AND ADJUST ALL FLUID LEVELS
DESCRIPTION:
SERVICE: INSPECT BODY PAINT AND CORROSION
DESCRIPTION:
SERVICE: INSPECT BRAKE LINES, HOSES AND CONNECTIONS
DESCRIPTION:
SERVICE: INSPECT DRIVE AXLE BOOTS
DESCRIPTION:
SERVICE: INSPECT ENGINE COOLANT LEVEL
DESCRIPTION:
SERVICE: INSPECT EXHAUST SYSTEM AND HEAT SHIELDS
DESCRIPTION:
SERVICE: INSPECT FRONT AND REAR BRAKE PADS, CALIPERS AND ROTORS
DESCRIPTION:
SERVICE: INSPECT INSTALLATION OF DRIVER\'S FLOOR MAT
DESCRIPTION:
SERVICE: INSPECT RACK AND PINION ASSEMBLY
DESCRIPTION:
SERVICE: INSPECT STEERING OPERATION AND LINKAGE
DESCRIPTION:
SERVICE: INSPECT SUSPENSION BALL JOINTS
DESCRIPTION:
SERVICE: INSPECT WIPER BLADES
DESCRIPTION:
SERVICE: PERFORM MULTI-POINT INSPECTION -
DESCRIPTION: PERFORM MULTI-POINT INSPECTION - ~ ~PERFORM MULTI-POINT INSPECTION - ~ ~ ~ ~16855 0 PERFORMED MULIT-POINT CLASS INSPECTION
SERVICE: REPLACE BATTERY(S) IN MASTER KEY
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
SERVICE: ROTATE TIRES
DESCRIPTION:
SERVICE: SERVICE - 15,000 MILES
DESCRIPTION: SERVICE - 15,000 MILES ~ ~SERVICE - 15,000 MILES ~ ~ ~ ~1683 15K SERVICE 70 PERFORMED MAINTENANCE SERVICE AS PRESCRIBED BY LEXUS FRONT BRAKE PADS HAVE 8.0 MM REMAINING FRONT TIRES HAVE 7/32" OF TREAD REMAINING REAR BRAKE PADS HAVE 8.0 MM REMAINING REAR TIRES HAVE 6/32" OF TREAD REMAINING SET TIRE PRESSURES TO
10866 MILES
DATE: 08/10/2016
REPAIR# 0071146
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION: PERFORM MULTI-POINT INSPECTION - ~ ~PERFORM MULTI-POINT INSPECTION - ~ ~ ~ ~10866 0 PERFORMED MULIT-POINT CLASS INSPECTION
SERVICE: REPLACE CABIN AIR FILTER
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL FILTER
DESCRIPTION:
SERVICE: RESET SERVICE INDICATOR
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 10,000 MILE COMPLIMENTARY SERVICE - SYNTHETIC OIL VEHICLES
DESCRIPTION: SERVICE - 10,000 MILE COMPLIMENTARY SERVICE - SYNTHETIC OIL VEHICLES ~ ~SERVICE - 10,000 MILE COMPLIMENTARY SERVICE - SYNTHETIC OIL VEHICLES ~ ~. ~ ~10866 50 SET TIRE PRESSURES TO MANUFACTURES SPECIFICATION RIGHT FRONT 32 RIGHT REAR 32 LEFT FRONT 32 LEFT REAR 32FRONT TIRES HAVE 7/32" OF TREAD REMAININGREAR TIRES HAVE 7/32" OF TREAD REMAININGREAR BRAKE PADS HAVE 8.0 MM REMAININGPERFORMED MAINTENANCE SE
5619 MILES
DATE: 02/18/2016
REPAIR# 0060679
DESCRIPTION:
DESCRIPTION:
SERVICE: INSPECT INSTALLATION OF DRIVER'S FLOOR MAT
DESCRIPTION:
DESCRIPTION:
SERVICE: PERFORM LEXUS PERSONALIZED SETTINGS
DESCRIPTION:
DESCRIPTION: PERFORM MULTI-POINT INSPECTION - ~ ~PERFORM MULTI-POINT INSPECTION - ~ ~ ~ ~5619 0 PERFORMED MULIT-POINT CLASS INSPECTION
DESCRIPTION:
SERVICE: ROAD TEST
DESCRIPTION:
DESCRIPTION:
SERVICE: SERVICE - 5,000 MILE COMPLIMENTARY SERVICE - SYNTHETIC OIL VEHICLES
DESCRIPTION: SERVICE - 5,000 MILE COMPLIMENTARY SERVICE - SYNTHETIC OIL VEHICLES ~ ~SERVICE - 5,000 MILE COMPLIMENTARY SERVICE - SYNTHETIC OIL VEHICLES ~ ~. ~ ~5616 30 PERFORMED MAINTENANCE SERVICE AS PRESCRIBED BY LEXUS FRONT BRAKE PADS HAVE 10.0 MM REMAINING FRONT TIRES HAVE 9/32" OF TREAD REMAINING REAR BRAKE PADS HAVE 8.0 MM REMAINING REAR TIRES HAVE 8/32" OF TREAD REMAINING SET TIRE PRESSURES TO MANUFACTURE
8 MILES
DATE: 09/04/2015
REPAIR# 0275309
REPORTED BY: DCH Lexus of Oxnard
SERVICE: PDI DETAIL RECON
DESCRIPTION: PDI DETAIL RECON ~ ~PDI DETAIL RECON ~ ~
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~ ~PDI
TERMS AND CONDITIONS
Old Oct 24, 2017 | 11:58 AM
chuck1022's Avatar
chuck1022
Default 28000 miles,
28048 MILES
DATE: 09/14/2017
REPAIR# 0082720
SERVICE: PERFORMED 30,000 MILE SERVICE INTERVAL OR 36 MONTH INTERVAL REPLACED AIR FILT
DESCRIPTION: PERFORMED 30,000 MILE SERVICE INTERVAL OR 36 MONTH INTERVAL REPLACED AIR FILT ~ ~PERFORM OIL AND FILTER CHANGE, TIRE ROTATION ~ ~ ~ ~PERFORMED 30,000 MILE SERVICE INTERVAL OR 36 MONTH INTERVAL REPLACED AIR FILTER REPLACED A/C FILTER REPLACED OIL AND FILTER REPLACED WIPERS REPLACED REAR BRAKE PADS PROGRAM 2ND KEY FOB
23341 MILES
DATE: 05/16/2017
REPAIR# 0444109
REPORTED BY: Jim Falk Lexus of Beverly Hills
SERVICE: MOVED TO: 444109C LINE: A
DESCRIPTION: MOVED TO: 444109C LINE: A ~ ~MOVED TO: 444109C LINE: A ~ ~
SERVICE: MOVED TO: 444109C LINE: B
DESCRIPTION: MOVED TO: 444109C LINE: B ~ ~MOVED TO: 444109C LINE: B ~ ~
SERVICE: MOVED TO: 444109C LINE: C
DESCRIPTION: MOVED TO: 444109C LINE: C ~ ~MOVED TO: 444109C LINE: C ~ ~
SERVICE: MOVED TO: 444109C LINE: D
DESCRIPTION: MOVED TO: 444109C LINE: D ~ ~MOVED TO: 444109C LINE: D ~ ~
SERVICE: MOVED TO: 444109C LINE: E
DESCRIPTION: MOVED TO: 444109C LINE: E ~ ~MOVED TO: 444109C LINE: E ~ ~
SERVICE: MOVED TO: 444109C LINE: F
DESCRIPTION: MOVED TO: 444109C LINE: F ~ ~MOVED TO: 444109C LINE: F ~ ~
SERVICE: MOVED TO: 444109C LINE: G
DESCRIPTION: MOVED TO: 444109C LINE: G ~ ~MOVED TO: 444109C LINE: G ~ ~
SERVICE: RADIATOR ASSEMBLY
DESCRIPTION: RADIATOR ASSEMBLY ~ ~RADIATOR IS LEAKING FLUID. ~ ~EXCESS CLEARANCE BETWEEN LOWER TANK AND CORE. SEAL DEFORMED. ~ ~23339 DURING INSPECTION FOUND RADIATOR LEAKING COOLANT WARRANTY CODE 160011 T1 13 T2 57 190 REPLACE RADIATOR ASSY WARRANTY CODE # 160011 T1 13 T2 57
23341 MILES
DATE: 05/04/2017
REPAIR# 444109C
SERVICE:
DESCRIPTION: PERFORMED FOUR WHEEL ELECTRONIC WHEEL ALIGNMENT, INCLUDING FRONT AND REAR TOE, CAMBER, CASTER ANDLOAN CAR IS COMPLIMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOUR ~ ~LOAN CAR IS COMPLIMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOUR VEHICLE IS READY. PLEASE RETURN VEHICLE WITH THE SAME FUEL LEVEL. ALL VEHICLES ARE NON-SMOKING. ~ ~ ~ ~23339 PROVIDED OUR CUSTOMER WITH A COURTESY VEHICLE.LOAN CAR IS COMPLIMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOURCHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AN ~ ~CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AND NON-OEM MATS & PLACE IN TRUNK. ~ ~ ~ ~23339 VERIFIED DRIVER'S FLOOR MAT IS SECURE. REMOVED AFTER MARKET MAT ( IF APPLICABLE) AND PLACED INTO REAR OF VEHICLE.CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)ANTIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR ~ ~TIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR OWNER'S MANUAL. LIST COMPLIES WITH THE CARB REQUIREMENTS.LF___LR___RF___RR___ ~ ~ ~ ~23339 ADJUSTED TIRE PRESSURE: LF_36__, RF__36_, LR__36_, RR36___.TIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM ORREPLACED FRONT BRAKE PADS, MACHINED ROTORS USING PRO-CUT, ADDED NON-DIRECTIONAL FINISH, CLEANED AL ~ ~REPLACED FRONT BRAKE PADS, MACHINED ROTORS USING PRO-CUT, ADDED NON-DIRECTIONAL FINISH, CLEANED ALL SLIDING AREAS AND LUBRICATED CALIPER SLIDE PINS (IF EQUIPPED). ~ ~REGULAR MAINT ~ ~23339 REGULAR MAINT 200 REPLACE FRONT BRAKE PAD AND ROTORS MACHINEREPLACED FRONT BRAKE PADS, MACHINED ROTORS USING PRO-CUT, ADDED NON-DIRECTIONAL FINISH, CLEANED ALMOUNT AND BALANCE THREE TIRES - REPLACE VALVE STEM OR FITTING KIT - COMPUTER BALANCE TIRE - SET TI ~ ~REPLACE BOTH FRONT TIRES AND LEFT REAR TIRE ~ ~REHULAR MAINT R ~ ~23339 REHULAR MAINT R 120 REPLACE 3 TIRES DOT # V4FO AMOR 1916 X [3] OLD DOT # M61V JA1R 3016 X [3]MOUNT AND BALANCE THREE TIRES - REPLACE VALVE STEM OR FITTING KIT - COMPUTER BALANCE TIRE - SET TI
SERVICE: ADD HIGH CONCENTRATE FUEL ADDITIVE TO FUEL SYSTEM
DESCRIPTION:
SERVICE: COMPLIMENTARY VEHICLE INSPECTION
DESCRIPTION: COMPLIMENTARY VEHICLE INSPECTION ~ ~COMPLIMENTARY VEHICLE INSPECTION ~ ~ ~ ~23339 FRONT BRAKE PADS 2 TIRES WORN OUT RADIATOR LEAKING COOLANT
SERVICE: PERFORM SCHEDULED MAINTENANCE EVERY 24 MONTHS OR 20,000 MILES.
DESCRIPTION: PERFORM SCHEDULED MAINTENANCE EVERY 24 MONTHS OR 20,000 MILES. ~ ~PERFORM SCHEDULED MAINTENANCE EVERY 24 MONTHS OR 20,000 MILES. ~ ~PERFORM 20K ~ ~23339 PERFORM 20K 290 SERVICED 20K, ALIGNMENT, FUEL ADDITIVE, AC AND ENGINE FILTERS REPLACED OIL AND OIL FILTER, CHANGED ENGINE AND AD FILTERS TIRE READINGS: LF: 10/32 RF: REPLACED, LR: REPLACED, RR: REPLACED REPLACED FRONT BRAKES. REPLACED RADIATOR. BRAK
SERVICE: REPLACE IN CABIN HEATING AND VENTILATION FILTER
DESCRIPTION:
SERVICE: REPLACED ENGINE AIR FILTER
DESCRIPTION:
SERVICE: REPLENISH WIPER SOLVENT
DESCRIPTION:
17948 MILES
DATE: 01/09/2017
REPAIR# 0435803
SERVICE:
DESCRIPTION: CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AN ~ ~CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AND NON-OEM MATS & PLACE IN TRUNK. ~ ~ ~ ~17948 VERIFIED DRIVER'S FLOOR MAT IS SECURE. REMOVED AFTER MARKET MAT ( IF APPLICABLE) AND PLACED INTO REAR OF VEHICLE.CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AN
DESCRIPTION:
DESCRIPTION: COMPLIMENTARY VEHICLE INSPECTION ~ ~COMPLIMENTARY VEHICLE INSPECTION ~ ~ ~ ~17948 FRONT BRAKES REPORTED AT: 6MM REAR BRAKES REPORTED AT: 7NN FRONT TIRES REPORTED AT: LEFT FRONT TIRE 7/32, RIGHT FRONT 6/32 REAR TIRES REPORTED AT: 8/32 BATTERY TESTED GOOD THANK YOU FOR GIVING ME AN OPPORTUNITY TO SERVICE YOUR VEHICLE. YOU MAY RECEI
SERVICE: DEFAULT
DESCRIPTION: DEFAULT ~ ~LOAN CAR IS COMPLEMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOUR VEHICLE IS READY. PLEASE RETURN VEHICLE WITH THE SAME FUEL LEVEL. ALL VEHICLES ARE NON-SMOKING. ~ ~ ~ ~17948 PROVIDED OUR CUSTOMER WITH A COURTESY VEHICLE.DEFAULT ~ ~TIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR OWNER'S MANUAL. LIST COMPLIES WITH THE CARB REQUIREMENTS.LF___LR___RF___RR___ ~ ~ ~ ~17948 ADJUSTED TIRE PRESSURE: LF_32__, RF_32__, LR_32__, RR__32_.
SERVICE: PERFORM SCHEDULED 15,000 MILE OR 18 MONTH SERVICE
DESCRIPTION: PERFORM SCHEDULED 15,000 MILE OR 18 MONTH SERVICE ~ ~PERFORM SCHEDULED 15,000 MILE OR 18 MONTH SERVICE ~ ~REGULAR MAINTENANCE ~ ~17948 100 15K SERVICE PERFORMED
SERVICE: PERFORMED FOUR WHEEL ELECTRONIC WHEEL BALANCE
DESCRIPTION:
DESCRIPTION:
12000 MILES
DATE: 08/03/2016
REPAIR# 0423919
SERVICE: 10,000 MILE FULL SERVICE
DESCRIPTION: 10,000 MILE FULL SERVICE ~ ~10,000 MILE FULL SERVICE ~ ~10K MAINTENANCE ~ ~12000 110 10,000 MILE FULL SERVICE PERFORMED
SERVICE: MOVED TO: 423919C LINE: A
DESCRIPTION: MOVED TO: 423919C LINE: A ~ ~MOVED TO: 423919C LINE: A ~ ~
SERVICE: MOVED TO: 423919C LINE: B
DESCRIPTION: MOVED TO: 423919C LINE: B ~ ~MOVED TO: 423919C LINE: B ~ ~
SERVICE: MOVED TO: 423919C LINE: C
DESCRIPTION: MOVED TO: 423919C LINE: C ~ ~MOVED TO: 423919C LINE: C ~ ~
SERVICE: MOVED TO: 423919C LINE: D
DESCRIPTION: MOVED TO: 423919C LINE: D ~ ~MOVED TO: 423919C LINE: D ~ ~
SERVICE: MOVED TO: 423919C LINE: E
DESCRIPTION: MOVED TO: 423919C LINE: E ~ ~MOVED TO: 423919C LINE: E ~ ~
12000 MILES
DATE: 08/01/2016
REPAIR# 423919C
SERVICE:
DESCRIPTION: PERFORMED FOUR WHEEL ELECTRONIC WHEEL ALIGNMENT, INCLUDING FRONT AND REAR TOE, CAMBER, CASTER AND ~ ~PERFORMED FOUR WHEEL ELECTRONIC WHEEL ALIGNMENT, INCLUDING FRONT AND REAR TOE, CAMBER, CASTER AND THRUST ANGLE - MEASURE SAI AND IA, CROSS TOE, CROSS CAMBER AND CROSS CASTER - TEST DRIVE TO VERIFY CORRECT OPERATION. ~ ~REGULAR MAINTENANCE ~ ~12000 150 PERFORM FOUR WHEEL ELECTRONIC ALIGNMENT - ADJUST FRONT AND REAR CASTER, CAMBER AND TOE - MEASURE THRUST ANGLE, SAI AND IA - TEST DRIVEPERFORMED FOUR WHEEL ELECTRONIC WHEEL ALIGNMENT, INCLUDING FRONT AND REAR TOE, CAMBER, CASTER ANDLOAN CAR IS COMPLIMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOUR ~ ~LOAN CAR IS COMPLIMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOUR VEHICLE IS READY. PLEASE RETURN VEHICLE WITH THE SAME FUEL LEVEL. ALL VEHICLES ARE NON-SMOKING. ~ ~ ~ ~12000 PROVIDED OUR CUSTOMER WITH A COURTESY VEHICLE.LOAN CAR IS COMPLIMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOURTIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR ~ ~TIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR OWNER'S MANUAL. LIST COMPLIES WITH THE CARB REQUIREMENTS.LF___LR___RF___RR___ ~ ~ ~ ~12000 ADJUSTED TIRE PRESSURE: LF__32_, RF__32_, LR_32__, RR_32__.TIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR
DESCRIPTION: COMPLIMENTARY VEHICLE INSPECTION ~ ~COMPLIMENTARY VEHICLE INSPECTION ~ ~ ~ ~12000 COMPLIMENTARY VEHICLE INSPECTION
SERVICE: COMPLIMENTARY WASH
DESCRIPTION: COMPLIMENTARY WASH ~ ~COMPLIMENTARY WASH ~ ~ ~ ~12000 COMPLIMENTARY WASH.
6165 MILES
DATE: 02/10/2016
REPAIR# 0409516
SERVICE:
DESCRIPTION: CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AN ~ ~CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AND NON-OEM MATS & PLACE IN TRUNK. ~ ~ ~ ~VERIFIED DRIVER'S FLOOR MAT IS SECURE. REMOVED AFTER MARKET MAT ( IF APPLICABLE) AND PLACED INTO REAR OF VEHICLE.CHECK DRIVER'S FLOOR MAT & VERIFY SECURED AND TABS IN PLACE. REMOVE ADDITIONAL MATS (SINGLE MAT)AN
SERVICE: DEFAULT
DESCRIPTION: DEFAULT ~ ~5,000 MILE LIGHT SERVICE ~ ~SCHEDULED MAINTENANCE ~ ~SCHEDULED MAINTENANCE 50 PERFORMED 5K SERVICE: TIRE ROTATIONDEFAULT ~ ~LOAN CAR IS COMPLEMENTARY / COURTESY RENTAL VEHICLE AGREEMENT GOOD UP TO 24HRS FROM THE TIME YOUR VEHICLE IS READY. PLEASE RETURN VEHICLE WITH THE SAME FUEL LEVEL. ALL VEHICLES ARE NON-SMOKING. ~ ~ ~ ~PROVIDED OUR CUSTOMER WITH A COURTESY VEHICLE.DEFAULT ~ ~TIRES INFLATED TO FACTORY SETTINGS FOR PSI BASED ON TIRE INFLATION PLACARD LOCATED ON DOOR JAM OR OWNER'S MANUAL. LIST COMPLIES WITH THE CARB REQUIREMENTS.LF___LR___RF___RR___ ~ ~ ~ ~ADJUSTED TIRE PRESSURE: LF_35__, RF__35_, LR_35__, RR_35__.
3 MILES
DATE: 08/31/2015
REPAIR# 0396883
SERVICE: PRE DELIVERY SERVICE LS430/SC430/GS430/GS300/ES300 IS300/LX470/GX470/RX330
DESCRIPTION: PRE DELIVERY SERVICE LS430/SC430/GS430/GS300/ES300 IS300/LX470/GX470/RX330 ~ ~PRE DELIVERY SERVICE LS430/SC430/GS430/GS300/ES300 IS300/LX470/GX470/RX330 ~ ~PDS
TE
Old Oct 24, 2017 | 12:01 PM
chuck1022's Avatar
chuck1022
Default 18000 mile RX, cant tell where it was bought/put in service
18436 MILES
DATE: 08/03/2017
REPAIR# 0077418
DESCRIPTION: PERFORMED 30,000 MILE SERVICE INTERVAL OR 36 MONTH INTERVAL REPLACED AIR FILT ~ ~PERFORM OIL AND FILTER CHANGE, TIRE ROTATION ~ ~ ~ ~PERFORMED 30,000 MILE SERVICE INTERVAL OR 36 MONTH INTERVAL REPLACED AIR FILTER REPLACED A/C FILTER REPLACE... READ MORE
SERVICE: REPLACE TWO TIRES. MOUNT AND BALANCE + REPLACE TIRE WEIGHTS
DESCRIPTION: REPLACE TWO TIRES. MOUNT AND BALANCE + REPLACE TIRE WEIGHTS ~ ~REPLACE TWO TIRES. INCLUDES MOUNT AND BALANCE + REPLACE TIRE WEIGHTS ~ ~ ~ ~REPLACE TWO TIRES. MOUNT AND BALANCE + REPLACE TIRE WEIGHTS
10214 MILES
DATE: 03/07/2016
REPAIR# 0014286
SERVICE: GUEST REQUEST ADVISOR: ARBI DER KRIKORIAN
DESCRIPTION: GUEST REQUEST ADVISOR: ARBI DER KRIKORIAN ~ ~GUEST REQUEST ADVISOR: ARBI DER KRIKORIAN - GUEST PERSONALLY ASKED FOR ARBI D.K. ~ ~ ~ ~GUEST REQUEST ADVISOR: ARBI DER KRIKORIAN
SERVICE: INSPECTED DRIVER'S FLOOR MAT FOR PROPER INSTALLATION
DESCRIPTION: INSPECTED DRIVER'S FLOOR MAT FOR PROPER INSTALLATION ~ ~INSPECT DRIVER'S FLOOR MAT FOR PROPER INSTALLATION ~ ~ ~ ~INSPECTED DRIVER'S FLOOR MAT FOR PROPER INSTALLATION
SERVICE: PERFORMED 15,000 MILES SERVICE
DESCRIPTION: PERFORMED 15,000 MILES SERVICE ~ ~PERFORM 15,000 MILES SERVICE ~ ~ ~ ~PERFORMED 15,000 MILES SERVICE
SERVICE: RF-36 PSI,LF- 36PSI,RR- 36PSI,LR- 36PSI.AMBIENT TEMP- DEG. FAHRENHEIT
DESCRIPTION: RF-36 PSI,LF- 36PSI,RR- 36PSI,LR- 36PSI.AMBIENT TEMP- DEG. FAHRENHEIT ~ ~TIRE PRESSURE CHECK AND INFLATE SERVICE ~ ~ ~ ~RF-36 PSI,LF- 36PSI,RR- 36PSI,LR- 36PSI.AMBIENT TEMP- DEG. FAHRENHEIT
6823 MILES
DATE: 08/01/2015
REPAIR# 0089723
DESCRIPTION: INSPECTED DRIVER'S FLOOR MAT FOR PROPER INSTALLATION ~ ~INSPECT DRIVER'S FLOOR MAT FOR PROPER INSTALLATION ~ ~DONE ~ ~INSPECTED DRIVER'S FLOOR MAT FOR PROPER INSTALLATION
SERVICE: PERFORMED 10,000 MILES SERVICE. BRAKES = FRONT- 9MM. REAR - 9MM. TIRES LF 8
DESCRIPTION: PERFORMED 10,000 MILES SERVICE. BRAKES = FRONT- 9MM. REAR - 9MM. TIRES LF 8 ~ ~PERFORM 10,000 MILES SERVICE ~ ~AS PER MAINTENANCE INTERVAL ( EVERY 6 MONTHS OR EVERY 5000 MILES) ~ ~PERFORMED 10,000 MILES SERVICE. BRAKES = FRONT- 9MM. REAR - ... READ MORE
SERVICE: REPAIRED FLAT TIRE. OK NOW
DESCRIPTION: REPAIRED FLAT TIRE. OK NOW ~ ~GUEST STATES TIRE LIGHT CAME ON LAST NIGHT, INSPECT AND ADVISE ~ ~FOUND RIGHT REAR TIRE HAS NAIL, LEAKING, REPAIRABLE. ~ ~REPAIRED FLAT TIRE. OK NOW
SERVICE: RF- 33PSI,LF- 33 PSI,RR- 33 PSI,LR- 33 PSI, SPARE 60PSI .AMBIENT TEMP- 82 DEG
DESCRIPTION: RF- 33PSI,LF- 33 PSI,RR- 33 PSI,LR- 33 PSI, SPARE 60PSI .AMBIENT TEMP- 82 DEG ~ ~TIRE PRESSURE CHECK AND INFLATE SERVICE ~ ~ ~ ~RF- 33PSI,LF- 33 PSI,RR- 33 PSI,LR- 33 PSI, SPARE 60PSI .AMBIENT TEMP- 82 DEG. FAHRENHEIT
SERVICE: TEST DROVE ABOUT 1.5 MILES UP AND DOWN, BRAKES STOPPING NORMALY, BRAKES OPERAT
DESCRIPTION: TEST DROVE ABOUT 1.5 MILES UP AND DOWN, BRAKES STOPPING NORMALY, BRAKES OPERAT ~ ~GUEST STATES AT TIMES WHEN BRAKING TAKES TOO LONG TO STOP, INSPECT AND ADVISE ~ ~ ~ ~TEST DROVE ABOUT 1.5 MILES UP AND DOWN, BRAKES STOPPING NORMALY, BRAKES O... READ MORE
5457 MILES
DATE: 05/06/2015
REPAIR# 0079337
REPORTED BY:
SERVICE: PERFORMED MACHINING OF FRONT BRAKE ROTORS / REUSING BRAKE PADS STILL @ 8 MM R
DESCRIPTION: PERFORMED MACHINING OF FRONT BRAKE ROTORS / REUSING BRAKE PADS STILL @ 8 MM R ~ ~GUEST STATES THE BRAKES VIBRATE WHEN APPLIED /GOING DOWN HILL ON FREEWAY ~ ~VERIFIED BRAKE PULSATION OCCURS @ 65 MPH FREEWAY DRIVING - FOUND FROM OUTSIDE INFLU... READ MORE
SERVICE: RF-34 PSI,LF- 34 PSI,RR- 34 PSI,LR- 34 PSI
DESCRIPTION: RF-34 PSI,LF- 34 PSI,RR- 34 PSI,LR- 34 PSI ~ ~TIRE PRESSURE CHECK AND INFLATE SERVICE ~ ~DONE ~ ~RF-34 PSI,LF- 34 PSI,RR- 34 PSI,LR- 34 PSI
SERVICE: THANK YOU
DESCRIPTION: THANK YOU ~ ~12 MONTH SERVICE HAS BEEN SCHEDULED FOR YOU ON 07/15/2015. ~ ~NOTE FOR GUEST ~ ~THANK YOU
SERVICE: THANK YOU FOR CHOOSING LEXUS OF GLENDALE!!
DESCRIPTION: THANK YOU FOR CHOOSING LEXUS OF GLENDALE!! ~ ~LEXUS OF GLENDALE SERVICE ~ ~ ~ ~THANK YOU FOR CHOOSING LEXUS OF GLENDALE!!
3817 MILES
DATE: 02/11/2015
REPAIR# 0070091
REPORTED BY:
SERVICE: PERFORMED 5,000 MILES SERVICE
DESCRIPTION: PERFORMED 5,000 MILES SERVICE ~ ~PERFORM 5,000 MILES SERVICE ~ ~AS RECOMMENDED ~ ~PERFORMED 5,000 MILES SERVICE
SERVICE: RF-38 PSI,LF- 38PSI,RR- 38PSI,LR- 38PSI.AMBIENT TEMP- DEG. FAHRENHEIT
DESCRIPTION: RF-38 PSI,LF- 38PSI,RR- 38PSI,LR- 38PSI.AMBIENT TEMP- DEG. FAHRENHEIT ~ ~TIRE PRESSURE CHECK AND INFLATE SERVICE ~ ~ ~ ~RF-38 PSI,LF- 38PSI,RR- 38PSI,LR- 38PSI.AMBIENT TEMP- DEG. FAHRENHEIT
11 MILES
DATE: 07/24/2014
REPAIR# 0048319
REPORTED BY:
DESCRIPTION: DETAIL PERFORMED & INSTALL PLATES & FRAMES ~ ~NEW LEXUS DETAIL & INSTALL FRAMES / PLATES ~ ~ ~ ~DETAIL PERFORMED & INSTALL PLATES & FRAMES
SERVICE: PRE DELIVERY SERVICE COMPLETED
DESCRIPTION: PRE DELIVERY SERVICE COMPLETED ~ ~PRE DELIVERY SERVICE ~ ~ ~ ~PRE DELIVERY SERVICE COMPLETED
Old Oct 24, 2017 | 12:02 PM
chuck1022's Avatar
chuck1022
Any of those 3 service reports jumping out at anyone for good or bad reasons?
Old Oct 24, 2017 | 12:26 PM
SkiMe's Avatar
SkiMe
Looks pretty clean and normal. The only two things that caught my eye were the rotors turned around 5k and the radiator replacement.
It does look like later on they did a full brake service, too.
Otherwise, normal notes I'd expect to see from the Lexus "checklist" in their service manual.
It is interesting to see the rest of the note on pulsation at 5k. Said by "outside influence"......
And the next service, customer says it doesn't stop very well. Almost sounds like someone was trying to get new rotors/pads?!?
Old Oct 24, 2017 | 12:35 PM
SkiMe's Avatar
SkiMe
And just recently installed a new battery. Nice to have a fresh one in there.
Old Oct 24, 2017 | 02:38 PM
chuck1022's Avatar
chuck1022
each one of those posts is a separate vehicle service history, kinda confusing...I read it after I posted . those are the 3 vehicles I am looking at buying..all seem decent.
Old Oct 24, 2017 | 03:08 PM
SkiMe's Avatar
SkiMe
OK, gotcha....now makes sense.
So first one: Nice that it has all 4 new tires. I notice the others either have 2 or 3 tires replaced. Our 2013 also had varying tire wears. Similar to the 3 scenario. One was pretty new, two others slightly more worn and a 4th very worn. They were Pirelli's and make all kinds of thumping noise. I did not like them. Now that winter is around the corner I just replaced them with Michelins.....WAY better now!
Also, going over bumps, my steering wheel seem to move around a bit. After new tires, I have not noticed....so having all 4 matching tires I think, are important on these vehicles. Also, based off of my 07', the most I've gotten out of tires range 30-35k. I went through several sets of tires and this was the consistent amount of life. I am expecting the same tire life on the 2013. So the first one having new tires is a big plus. Also has new battery.
Second and third have had the brakes touched and seems a little early. I'd check out the amount of wear on the first one...but if certified, it has to pass a minimum thickness so I would suspect still OK.
New pads at 25k seems short in life to me.
One bonus on ours is the HID display. Very surprised how nice that feature is!!
