O2 Sensor Location
Old Oct 28, 2016 | 03:37 PM
dwlink's Avatar
dwlink
Default O2 Sensor Location
Got a code P0157 which is for O2 sensor 2 in bank 2. I know it should be downstream of the cat, but does anyone happen to have a diagram I could reference. Would like to test it and see if the issue is just a simple replacement that I could DIY. Thanks
Old Oct 29, 2016 | 07:07 AM
ColAngus's Avatar
ColAngus
Have you crawled under the vehicle and you were unable to find it? If not, how is a diagram going to help you?
Just replace it and I'd also assume that'll fix your issue.
Old Oct 29, 2016 | 07:10 AM
dwlink's Avatar
dwlink
Given that it "sensor 2", I assume there's also a sensor 1. Figured a diagram would help ID these so I don't waste my time taking off the wrong sensor. And yes I did find one crawling under there - just don't know which one it is.
Old Oct 29, 2016 | 07:57 AM
kitlz's Avatar
kitlz
No, I don't play soccer!
delink, maybe look at this thread. There was a service campaign on the O2 sensor. Check the Lexus Owner's website to see if your RX is included. Notices went out last year.
Old Feb 19, 2017 | 09:36 AM
dwlink's Avatar
dwlink
Finally got around to fixing this. Got lucky and swapped out the front O2 sensor downstream of the cat. So it looks like the convention in this generation of the RX is the front cylinders are bank 2 and the rear cylinders are bank 1. Very easy DIY - didn't even need to jack/lift the car.
Old Jul 7, 2017 | 01:06 AM
lexus1979's Avatar
lexus1979
dwlink,
I'm glad you fixed it.
I have the same issue with the P0157 code. Lexus service wants $710 for O2 b2s2 replacement.
Where did you get yours and how much it cost you?
Also, did you use any manuals to do this repair?
Could you please post a link or picture maybe?
Thanks in advance!
Old Jul 7, 2017 | 08:21 AM
salimshah's Avatar
salimshah
25 Year Member
Previous generation has the same convention.
It starts out with naming bank 1 or 2 based on TDC of cylinder 1 on start of combustion stroke. Then the engine got mounted transverse and bank 1 is on the fire wall side and 2 on the radiator side.
Salim
Old Aug 29, 2017 | 09:26 AM
Claydus's Avatar
Claydus
Default 2010 RX350 O2 Sensor Locations?
Just got a check engine light diagnosed at my local Lexus dealer today. They are showing a P0157 code for bank 2 sensor 2. I want to see if I can replace this part myself since the dealer has quoted my a small fortune to replace this sensor.
My understanding is that sensor 2 is post catalytic converter. Is this correct?
Also since this is bank 2 would be the front of the engine and theoretically the sensor "should" be easily accessible from under the car? Is this correct?
Has anyone attempted replacing this sensor? I can't find many resources about this by searching rx350 B2S2 and I figured I would ask around here.
Old Aug 29, 2017 | 01:06 PM
Clutchless's Avatar
Clutchless
Look at the link at post 3 in this https://www.clublexus.com/forums/rx-...ensor-1-a.html
Old Aug 31, 2017 | 07:30 AM
Claydus's Avatar
Claydus
Does anyone have the part number of Bank 2 Sensor 2?
They all look to be the same but the length of wire is the only difference that I can tell....
Old Aug 31, 2017 | 05:01 PM
Clutchless's Avatar
Clutchless
Call your local dealer.
Old Oct 11, 2019 | 04:19 AM
greg569's Avatar
greg569
Keep in mind the 2T2 vin numbers were made in Canada. If you don't have North American car number is different.
Use Vin Number.
Good luck!
SICK350
Mar 11, 2014 05:20 PM
ADENNARD
May 21, 2013 06:27 AM
ck42
Jul 30, 2012 10:23 AM
Eric00GS3
Mar 22, 2011 12:55 PM
