Headlamp washer cover
Old Jan 8, 2016 | 09:25 AM
DHarrietha's Avatar
DHarrietha
8th Gear
Default Headlamp washer cover
I have a 2015 RX 350 .. headlamp washer cover on drivers side was ripped off during car wash. Does anyone have the part # or know how to repair ... versus going to dealership. I can paint a new cover ... thanks,
Old Jan 8, 2016 | 03:48 PM
mcomer's Avatar
mcomer
They come prepainted, part number for it in White is 8535448010A0. About $20 US
Old Jan 9, 2016 | 10:06 AM
DHarrietha's Avatar
DHarrietha
8th Gear
Question Headlamp washer cover
Headlamp washer cover - RX 350 - cover got ripped off in carwash. I can't tell if actuator is gone or is retracted inside. Has anyone ordered the part and replaced their own? I beginning to feel this might have been a very expensive car wash. This is my first lexus .. so all tips tricks would be appreciated.
Old Jan 11, 2016 | 07:12 AM
mcomer's Avatar
mcomer
Most common is that the nozzle and the flat exterior cover were lifted by the carwash and popped off.
Might check with your carwash "lost & found" for it before buying a replacement. Repair is easy, just
press it into the opening, be sure to orient it correctly with the sprayer to the rear and push till it seats.
Old Jan 11, 2016 | 07:17 AM
DHarrietha's Avatar
DHarrietha
8th Gear
Hi, i did check with car wash ... they found cover .. but it is cracked and it looks like something broke off - versus popped off. It doesn't seem to snap onto the car anymore. I can't tell if the acutuator is still there ... would it be retracted into the hole? How does the cover attach to the actuator?
Old Jan 18, 2016 | 11:09 AM
DHarrietha's Avatar
DHarrietha
8th Gear
Default Headlamp Washer cover
Hi,
Recently my headlamp washer cover on the driver side of my 2015 lexus was ripped off in car washer.
Based on the passenger side, it looks like there is a tube, then a piece that attaches to the tube and then the cover. Is this correct ... are there 3 pieces or if there just the cover and the actuator (meaning the actuator is what is attached to the tube). This piece is also missing from my car. All input on repair solutions and costs appreciated. This is a leased vehicle.
Old Jan 19, 2016 | 12:11 PM
moose66's Avatar
moose66
See if this helps you at all. Lots of small parts in the diagram!
https://www.parts.com/index.cfm?fuse...iagram=8914788
Old Jan 19, 2016 | 12:23 PM
DHarrietha's Avatar
DHarrietha
8th Gear
The diagram really helps .... can I order each part individually. I need parts 1, 2, 3 and 9.
Old Jan 19, 2016 | 12:40 PM
moose66's Avatar
moose66
I would say build a cart on the website and see what it says. Typically you can order these items individually as typically you don't need the entire unit.
Old Dec 26, 2016 | 08:02 AM
ram350's Avatar
ram350
Hi did you successfully change the headlamp washer on your RX? I have similar issue with broken cover on my wife's RX. I have the part but looking for advice/instructions on changing it.
​​​​​​​Thanks in advance!
Akiva253
RX - 4th Gen (2016-2022)
Mar 14, 2021 10:23 PM
ato1999bet
Jun 21, 2019 09:19 PM
ziggyziggy
RX - 3rd Gen (2010-2015)
22
Jan 8, 2011 04:28 AM
