First oil change
Old Nov 18, 2015 | 11:21 AM
RealWing's Avatar
RealWing
Default First oil change
Completed the first oil change. Attached a photo of the original Lexus/Toyota filter and the Amsoil filter that I installed - for a comparison.
The original filter has a lot of pleats, but they are tightly sandwiched together which makes them somewhat less effective from my perspective.
I sent an oil sample for analysis, just to see if there are any initial problems with the engine. I'll post the results when I get them back.
__________________________________________________________
2015 RX350 F Sport, Claret Mica
2013 Toyota Venza, Touring, AWD
1970 Plymouth Superbird , 440-6bbl
1969 Plymouth Barracuda, 340 Formula S Fastback
1969 Barracuda convertible (conversion i/p with a 6.1 L Hemi transplant)
2015 BMW K1600 GTL
Attached Thumbnails First oil change-img_3273_1280x719.jpg   First oil change-img_3275_1280x719.jpg   First oil change-img_3274_1280x719.jpg
Old Nov 18, 2015 | 01:36 PM
JT4's Avatar
JT4
It will be interesting to see what the test results show. How many miles on the RX?
Old Nov 18, 2015 | 01:39 PM
RealWing's Avatar
RealWing
Only ~8000 Km (5000 miles)
2015 BMW K1600 GTL
Old Nov 18, 2015 | 07:28 PM
Henry82's Avatar
Henry82
+1 Waiting for your results
Old Nov 19, 2015 | 08:50 AM
charley95's Avatar
charley95
Just curious, Did you use Mobil 1? My 14 RX is due soon and have yet to buy the oil. It seems like there are 20 different versions of Mobil 1. If you did buy Mobil, which version did you buy?
I'm hoping W-Mart has it. This will be the first time I've changed the oil on this RX and I have yet to pick up a filter wrench. I might call the Toyota dealer and see what they have. Are people setting the torque on the filter cap? I have a torque wrench and would like to set it to spec. if possible.
Old Nov 19, 2015 | 08:56 AM
RealWing's Avatar
RealWing
I used Amsoil "Signature Series" 0w20.
I didnt use a torque wrench - just my "calibrated" hand
Old Nov 19, 2015 | 10:04 AM
Clutchless's Avatar
Clutchless
Just order this wrench from Amazon
Amazon.com: Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus: Automotive Amazon.com: Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus: Automotive
I too just calibrate my oil filter tightness by hand, relying on my experience to get it right. I would not trust a torque wrench at that low a level on something that fragile. And I don't want to buy an inch torque wrench for this. Get it hand tight, then place the wrench over it and go another quarter turn or so. I can feel it tighten up.
You need 0w-20. The Toyota version is made by Mobil to their specifications and according to the gurus at www.bobistheoilguy.com who have done VOA and UOA on the stuff, it is better than any other version of Mobil 1 0w-20. It is designed for the Toyota recommended 10,000 oil change interval. It is all I buy for my 2 Lexus'. Not much more than Mobil 1. However, any of the brand name synthetic 0w-20 oils are more than capable of protecting your engine. Pennzoil makes a great oil too!
Old Nov 19, 2015 | 10:06 AM
Freds430's Avatar
Freds430
I get my Mobil1 at Walmart 0-20. It usually runs around $24 for the five quart jug. I buy my filters from Lexus World for $6 each. Use cl10 for a 10% discount. I take the oil and filter to my local Toyota dealer who charges me $20 labor.
Old Nov 19, 2015 | 12:41 PM
ThChinaman's Avatar
ThChinaman
CL Folding 10,000
I use the Mobil1 0W20 Advanced Fuel Economy for my car. There are two 0W20's. This one has the green label.
As for the torque settings:
18ft-lbs / 25N m for oil filter cap to oil pan
10ft-lbs / 13N m for the oil filter drain plug to oil filter cap
30ft-lbs / 40N m for oil pan drain plug to oil pan
Old Nov 19, 2015 | 03:36 PM
charley95's Avatar
charley95
Thanks guys!
Old Nov 26, 2015 | 12:10 PM
RealWing's Avatar
RealWing
Default Analysis results
Got the results back. Everything looks ok for a first oil change.
The silicon levels are very high, but that is due to residual casting sand. The copper levels are somewhat higher than I expected due to initial bearing wear-in but I expect it to be back in spec at the next change.
Attached Thumbnails First oil change-nov-17-2015-engine-sample-report-pg-1.jpg   First oil change-nov-17-2015-engine-sample-report-pg-2.jpg
lc6888
Maintenance
Mar 24, 2023 07:19 AM
iseeu1001
Mar 3, 2016 05:36 PM
akim1220
Sep 22, 2013 08:51 AM
ISmak4
Feb 6, 2013 09:20 AM
Lextranny
Feb 6, 2005 03:35 AM
