Auto Headlight Issue
Old Jan 6, 2015 | 09:32 AM
rickchen's Avatar
rickchen
Default Auto Headlight Issue
When I go through a tunnel or under a bridge with my headlights on the Auto setting the lights will turn on, but wont turn themselves back off when it is no longer dark. Does anyone have any input on this?
Old Jan 6, 2015 | 11:23 AM
BertL's Avatar
BertL
Welcome to the forum.
Unsure what model year and options you own to be more specific, but there are a couple Customization options you can most likely change on your RX. Check your Owner's Manual under "Customization" and you'll see there are two Auto Light Control System options that you may need to tweak: "Time elapsed before headlights turn off" and "Light sensor sensitivity". If your lights never go off by themselves, I bet the first option is somehow "OFF"...
I'm thankful a Lexus has those options as my MBZ does not, and my headlights are some of the last on the highway to go off as sunrise happens each morning (at least they go off!).
Old Jan 6, 2015 | 11:44 AM
rickchen's Avatar
rickchen
Thank you for your reply. I have a 2011 RX350 with NAV. I thought the "Headlamps Auto-OFF timer" was for when you turn the vehicle off it stays on for an x amount of time.
Old Jan 6, 2015 | 11:55 AM
BertL's Avatar
BertL
Oops, yes, you're right on the timer. Sorry 'bout that. You can tell it's been a while since I've played with that setting.
Do try the sensitivity option though and see if you can make that help. For your 2011, info is in the manual on p625.
Old Jan 6, 2015 | 01:08 PM
rickchen's Avatar
rickchen
In the settings I also turned the DRL off. I wonder if that is the issue?
I looked all over the forums and I seem to be the only one with that problem.
Old Jan 6, 2015 | 01:20 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
rickchen, the headlights on my RXh stay on for maybe a minute after going under a bridge. It's not automatic and depends on how much light the sensor gets. The other timing settings are for when you exit the vehicle. Having them turn off completely when the door is opened is what I have mine on. It's convenient living in a state that requires headlights on when the wipers are on. They should also turn off when you hit the lock button on the fob twice IIRC. A quick way to turn off the headlights after going under an overpass or bridge is to turn the stalk on the side of the steering wheel one click in any direction and then back to auto. If that doesn't work, you might have a problem.
Old Jan 6, 2015 | 01:58 PM
BertL's Avatar
BertL
I doubt the DRL setting will have any impact. If the sensitivity option does not help after you've tried it in various settings, perhaps you're still under warranty and should have it looked at before your 4 years is up.
Side note in case it triggers a thought: You haven't accidentially covered or maybe coated the headlight sensor with dust, cleaning liquid, or maybe conditioner when detailing your dash, have you? May be worth checking and giving it a wipe with a clean microfiber towel to be sure. If you don't know, the sensor is next to the defogging vent on the passenger side of the dash up by the bottom of the windshield -- looks like a round button with a slot around it. It's easier to see standing outside the car and looking in the front window. Stickers on the window or something laying on the dash could interfere with it I suppose as well.
mate01
Jan 29, 2016 01:20 AM
myred86
RX - 3rd Gen (2010-2015)
Jun 25, 2014 01:00 PM
AnimalB
Jul 25, 2013 08:10 AM
turbon50
Jun 19, 2011 12:14 AM
afpj
Jun 2, 2010 08:31 PM
