TRC + VSC -simple question
Old Dec 18, 2014 | 09:26 AM
silverar's Avatar
silverar
Default TRC + VSC -simple question
is there is a problem when changing only the rear brakes ?. does the VSC&TRC will work as it should when the rear BRAKES (shoes only) are new and the front are old !
Old Dec 18, 2014 | 11:10 AM
vlad_a's Avatar
vlad_a
No, you're good. The pads will have the same clearance relative to the disk throughout their entire life. It is pistons that slowly extend to compensate for wear.
Old Dec 18, 2014 | 02:42 PM
silverar's Avatar
silverar
thanks for your reply . i changed only shoes . so everything fine as you said !
Old Dec 18, 2014 | 02:55 PM
vlad_a's Avatar
vlad_a
You're welcome!
Just for reference, shoes are located inside of a drum and pads are used in disk brake systems.
The rear disk also has a small drum in the middle for the parking brake, which does use shoes.
DaveXIX
Suspension and Brakes
Aug 10, 2013 05:03 AM
Rob6656
Oct 23, 2012 11:59 PM
Luin
Apr 24, 2007 12:45 AM
amati5
Jan 2, 2002 10:47 AM
