RX350 2013 ABS Brake Malfunction
Old Nov 25, 2013 | 05:04 AM
Bluesjam's Avatar
Bluesjam
I did not post the follow up on my ABS problem, but I got the email this morning on the new post so I will update. The dealership did say that the prpblem / codes had to be forwarded to Lexus corporate before it could be repaired. It was the ABS Actuator and they did replace it and have not had any problem since. You need to get it in as soon as possible. Here's a pic of my warning lights.
Old Nov 25, 2013 | 05:36 AM
mshumack's Avatar
mshumack
You mentioned there is a Technical Service Bulletin (TSB) on this issue. I had not thought about checking for TSBs lately - but on my last car (a Maxima) I would do this periodically to see if there was anything going on that I needed to be on the lookout for.
Even if your not aware of a problem, following the TSBs is helpful. For example there could be a TSB on fixing a rattle, that you have which you may not be too concerned with - then you see the TSB and bring the car to teh dealer to get it fixed (BTW - a TSB issued does not mean the reapir is free if you are out of your warranty period. It just means a problem/fix has been identified that is common to the model).
With all that said, I'm going to look for TSBs now on the RX. For example - I just found this one:
Bulletin Number: LSB-0019-13 Bulletin Date: 04-12-2013 Component:
171100 latches/locks/linkages:doors:latch Summary
Lexus: while driving, some vehicles would display an intermittent warning message, triggered by courtesy switch in back door lock when door is changed to open position, with hatch in closed position. models 2012-2013 rx350, rx450h.
Read more: http://engine-codes.com/tsb/lexus/rx...#ixzz2lfFrNrO3
Old Nov 25, 2013 | 03:54 PM
lohmell's Avatar
lohmell
This was the same issue, with the same warning lights I was having, there are a lot of warning lights coming on at once. I could also clear the condition by turning the car off and back on. The brakes still worked, but I imagine the ABS function was not working, when the ABS malfunction light was on. If the dealer replaces the ABS actuator, which includes the computer module for the ABS system, it should resolve the issue. It took my dealer some time to figure this out since the car's computer was not recording the event. So they kept my car for several days, with their own computer connected to it, and luckily they had the event occur so they could record what was causing it. SInce this was replaced 11 months ago I have not had a single issue. Initially the dealer thought maybe I had the car skid, since it happened when raining and you get the "skid" alarm light in addition to all the other lights/warnings. Then I had the event in dry weather. So the dealer said they would keep the car until they resolved the issue and gave me a free loaner (same style RX).
Old Dec 26, 2013 | 04:42 PM
Thesurgeon's Avatar
Thesurgeon
Default I have the same problem in my 2013 RX350
I am wandering how is your car running now after they had fixed the brake actuator malfunction. I am having the same issue right now and my car is being seen by lexus dealer and the mechanic told me there is something wro ng with the actuator...and it needs to be replaced..thanks God it happened while its still in warranty. And the lexus dealer here in Magnussen Fremont California is one of the best dealership around. Although i am not quite happy with what is going on with this new Lexus RX350 after it gave me this trouble, but i am relying on there expertise here to fix the problem...they also gave me a loaner until it will get fixed...
Old Dec 30, 2013 | 08:24 AM
lohmell's Avatar
lohmell
Since I had the ABS Actuator replaced almost 1 year ago, I have not had any other issues. It seems to be the right fix.
Old Dec 30, 2013 | 08:42 AM
rogerh00's Avatar
rogerh00
Veteran: Air Force
Since the actuator was replaced about 9 months ago I also have not had any problems. Just smooth sailing
Old Oct 14, 2020 | 06:26 PM
upucash3's Avatar
upucash3
Default Abs
My car show this brake malfunction last night after the abs censor was removed could.[
QUOTE=Bluesjam;8253102]I did not post the follow up on my ABS problem, but I got the email this morning on the new post so I will update. The dealership did say that the prpblem / codes had to be forwarded to Lexus corporate before it could be repaired. It was the ABS Actuator and they did replace it and have not had any problem since. You need to get it in as soon as possible. Here's a pic of my warning lights.
Attachment 426933[/QUOTE]
Gjohnson
Mar 5, 2020 05:45 AM
kdecluette
Jun 28, 2018 08:17 AM
kqmalik
RX - 3rd Gen (2010-2015)
18
Jun 5, 2016 11:55 AM
chungmeow
Sep 25, 2015 11:48 PM
