Battery Protection
Old Aug 3, 2012 | 07:17 PM
GRPFAN's Avatar
GRPFAN
Default Battery Protection
Anyone here use those red and green battery felt post pads on your battery to prevent corrosion?
I find there less messy then a coating of grease or vasoline.
Old Aug 3, 2012 | 07:24 PM
2011RX350's Avatar
2011RX350
Both are recommended, for different reasons. The red and green felt pieces are treated to neutralize the fumes while three grease keeps the corrosives away from the battery terminals and connectors.
Old Aug 3, 2012 | 07:37 PM
GRPFAN's Avatar
GRPFAN
Just curious on what others think.
I used them on my cars/trucks/boats/cycles/ and John Deere tractor batterys also.
They seem to do a good job.
Old Aug 4, 2012 | 12:04 PM
Quatro40's Avatar
Quatro40
Also don't forget to add distilled water to the battery, specially in this summer heat it is boiling away fast. Our OEM batteries are not maintenance free. Just open the two covers on the front right of the engine bay to access the battery. To see if it needs water look in the maintenance cap on the lower left corner if it is red or bluish red then you need to add water.
Old Aug 4, 2012 | 03:59 PM
Marqevans's Avatar
Marqevans
Wow wasn't aware of that. Ive had my 2012 for 3 months and I already had to replace the battery. Wonder if they never put enough water in.
Old Aug 4, 2012 | 04:17 PM
dctex99's Avatar
dctex99
My '13 has NO such window to check the battery so may be a sealed one like most are! It just says; Made by Johnson Controls for Toyota. They also make most SEARS Die Hards. They have since SEARS buyers were busted for taking bribes from Exide Battery a few years ago!! Must be a change from 2012! I cannot pry off the cap at all so pretty sure considered a "sealed" battery like most are these days!!
kazuto88
Dec 6, 2014 08:21 PM
chi123
Jun 14, 2012 11:17 AM
jbl-1985
RX - 1st Gen (1999-2003)
15
Nov 6, 2010 04:39 AM
