2011 RX Noises
Old Feb 14, 2012 | 06:06 PM
AlexB's Avatar
AlexB
Originally Posted by MEP7557
I dynamatted the entire interior of my RX and it did nothing for the exhaust note. It did get rid of some of the tire pinging when going over expansion joints. My ML sound system took a big step up. Lot's of bass response now and the sound is awesome
P
Alexb, I am curious as to where you saw the extra 'goop' on your RX. Placement is everything.
I didn't compare the cars side by side, but from my recollection, the trunk floor area around the spare tire above the muffler had more "goop" (probably seam sealer or some type of caulking). Since I did notice a reduction in exhaust noise between the '11 and the '12, I figured this had something to do with it.
Ever since I saw your earlier comments about improving the sound system with Dynamat, I've had it on my wish list of things to do. The trunk floor is easy, and the door panel removal looks fairly straight forward, but how do you get the rear panels off around the upper suround speakers and the subwoofer?
Old Feb 14, 2012 | 06:14 PM
markrivers's Avatar
markrivers
Originally Posted by LXGXSAM1
The experience I have with Toyota or Honda is the same. More than twenty years ago, these two companies put out vehicles that were very well insulated, I mean the foams below the carpet were thick and heavy! Then they keep reducing the padding, today all of them, including Lexus use materials that are so ineffective I feel like I was scammed! Do you have to spend $80+ grand to have a quiet vehicle nowadays? Do we have to give these car companies a huge profit margin? I say we should file a complaint for false advertisement (that the RX is a quiet vehicle).
i guess i can answer that for you.
the " quietness" in my Range Rover and our 2011 RX 350 is comparable..although sometimes i do feel that the RX 350 is Quieter.
Reliability wise, i would stick with the Lexus, or even a plain Toyota ( we have a 2009 Camry SE and a 2011 Prius IV).
in your case, i would think the 450h would better suit your needs than the 350.
Old Feb 14, 2012 | 06:31 PM
MEP7557's Avatar
MEP7557
Alexb
I did the entire bottom of the RX. I went around the wheel wells and the spare tire area. That achieved the best bass response as I did pull the sub and go around it and behind it. I did not go up around the satellite speakers, too much trouble. Not sure if removing the door panels is a good idea as you can end up with noises you didn't have before. I did however remove mine and insulated the doors sheet metal. I have a thread somewhere in here of when I did this. Need more info let me know.
Sub Removal
pgeremia
Hybrid Technology
Jun 6, 2021 10:11 AM
Dubbs
RX - 1st Gen (1999-2003)
May 9, 2017 03:52 PM
diverchris
RX - 3rd Gen (2010-2015)
18
Jan 10, 2016 06:47 AM
SirKnight
Sep 15, 2013 04:40 PM
