Where are you guys getting it from? I usually get my Mobil1 5-30 for my other cars at Walmart...but I have never seen 0-20 there. Guess I will have to check Advance Auto if anything.
at walmart, 5 quart jug of Mobil1 0w-20 are always out of stock and because its not one of the more common stock item, its not often to see them on the shelf. Last time I asked the floor person and found four 5quart jugs in the back which I grabbed all four for $23.xx each. last time we had gas price go up, same engine oil price went up almost to $26 for same 5 quart jug. one quart is also hard to find on the shelves and they are $6.xx per quart but they have it. I think Toyota is the only manufactural I know that uses 0w-20. Most I know on newer vehicles use 5w20 which are compatible with 0w-20.
Mobil One is great - or, if there's a local Toyota dealer they stock 0-20 oil for the Prius and if you buy a case of a dozen quarts at a time they usually discount it below $6/each.
I just picked up the Mobil1 0W-20 5qt from Walmart for $24.50 and stopped by O'reilly to get the 1 qt bottles for $4.99. Pretty good deal so I thought I stock up on those.
Ordered the oil filter (Toyota part number) from Sewell Lexus for a good price too.
In the future, I will be using Mobil 1 5W-20 since I own another vehicle (Acura) that requires the 5W-20. I do not believe that the 0W is needed in Oregon to justify it's use.
Jim, it takes a new mind set to convert to 0w20w after most of us grew up using 20w30w or higher. However this is a new 'low friction' engine family designed for the 0w20w oil. The book, the shop, and the engineers that designed it say stay with the correct lube. You'll actually have a longer life, more performance, and better mileage.
I've not found anyone in these forums yet that have experienced a problem with it. And the book does say if you had 5w20w in a change, it 'probably' won't hurt for 5k, but should be changed back to 0w20w ASAP.
Why do you need to justify the use of 0W20 oil, it is what Lexus recommands. Its only a $1 more a quart, so thats a extra $8 a year.
