door panel remove
Old Feb 2, 2011 | 01:43 PM
clickart's Avatar
clickart
Default door panel remove
can someone show me how to take the front passenger door panel off? I'm trying to fix the rattle in there( i think). it sounds like something it loose in there, i can hear it when i close the door or even in the bumpy road. thanks
Old Feb 2, 2011 | 01:49 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
MEP did a nice write-up.
https://www.clublexus.com/forums/rx-...he-scenes.html
Old Feb 2, 2011 | 01:54 PM
clickart's Avatar
clickart
yes i saw that one but i just want to take the panel off to see what's loose inside. i can't find any screws around the panel.
Old Feb 2, 2011 | 04:50 PM
TorontoIS's Avatar
TorontoIS
I've been having a rattling in the passenger front door that the dealership has yet to be able to fix. I've been three times and each time, it is good for a day. On bumps and really cold days it is quite frequent. It is a rattle, just as if a screw was stripped and loose in its socket. I hope that the next visit will fix it, but I wonder if there is a defect somewhere in the door panel and that it just needs to be replaced.
Old Feb 2, 2011 | 05:28 PM
MEP7557's Avatar
MEP7557
Look at other post regarding door panel removal.
Old Feb 3, 2011 | 07:24 AM
clickart's Avatar
clickart
that's exactly what i have. its loud when the weather is cold. look like its going to be a hard to fix rattle. i was going to take it off and see but i guess i'll leave it to the dealer when i bring it in. lets us know what you find out about it.
Old Feb 3, 2011 | 10:19 AM
TorontoIS's Avatar
TorontoIS
I won't be able to get back to the dealer for another three weeks. But once it is fixed, which I know it will be eventually, I will post about it.
Old Mar 26, 2011 | 10:13 AM
DwHBart's Avatar
DwHBart
Default Door panel removal RX350
I had to remove the front passenger door panel to replace the side mirror on a 2009 RX350 -
Hope this helps!
http://drivewayhandyman.com/behind-t...s/rx350mirror/
Old Mar 26, 2011 | 11:03 AM
MEP7557's Avatar
MEP7557
There are four screws to remove the door panel.
1. The rubber door stop on the inside of the door jam, visible.
2. One screw behind the plastic cover where you grab to open the door, it just snaps off.
3. In the armrest. This is where there is a piece of felt where you grab to pull the door shut. The felt is just snugly fit in to this opening, a small screwdriver to lift a corner and out it comes.
4. Underneath the power window/ mirror control in the armrest. With a plastic pry bar from the front of the control, lift up, this piece snaps into place.
The rest is held by plastic clips, after removing the screws pull from the bottom. Don't get too aggressive as there are several connections to the door panel. All the connections are plug and play nothing difficult at all.
Good Luck.
Old May 5, 2014 | 02:07 AM
learsid's Avatar
learsid
5th Gear
Hi guys, I tried this and no joy.
It looks like the back door panel is of 2 parts unlike the front which is all one.
Pulling on it from the bottom and pushing up only seems to push against the upper part which is not moving.
Old May 5, 2014 | 04:57 AM
SteveCraig's Avatar
SteveCraig
learsid,
Rear door panel pic.
http://lexus.sewellparts.com/images/...000/675943.jpg
Old May 5, 2014 | 07:58 AM
Dreamlab's Avatar
Dreamlab
At Chrysler they referred to these as BSR issues (Buzz-Squeak-Rattle)
Old May 5, 2014 | 08:44 AM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Unlike the front door, you'll need to remove the rear window trim to be able to remove the rear door panel.
See the DIY, Post #4 (Rear Door Squeaking Reduction) in:
https://www.clublexus.com/forums/rx-...r-squeaks.html
Wald GS
GS - 1st Gen (1993-1997)
Jul 25, 2010 05:58 PM
radio9
Jun 19, 2010 02:19 PM
1sxyrxy
Feb 9, 2006 05:34 PM
