Isn't Lexus RX windshield too soft?
Old 06-03-10, 03:19 PM
yanje03
yanje03's Avatar
Default Isn't Lexus RX windshield too soft?
My RX350' windshield got 2 big cracks in 1 year. I just feel the material of this windshield isn't good enough. Does anyone else has the same concern ?
Old 06-03-10, 03:48 PM
RXSF
RXSF's Avatar
common issue with modern day windshields. I dont know why. You really just have to avoid bigrigs and large trucks
Old 06-03-10, 07:23 PM
Cruiter
Cruiter's Avatar
Mine cracked right up the center while I was drying the car after I washed it. The dealer determined nothing hit it and replaced it with OEM windshield under warranty. The crack ran from an inch or two from the bottom about 2/3 of the way right up the center.
It's been fine and say's 'Lexus' on it. A glass company came to the dealer and they did it there.
Old 06-04-10, 04:52 PM
redrocks
redrocks's Avatar
Cost cutting...cheap, cheap
Old 06-04-10, 07:20 PM
Cruiter
Cruiter's Avatar
I wouldn't say that. How could you ??? Sometimes things just happen w/o explanation. In the new Consumer Reports the 2010 RX 450h, and 350 came out 1st and 3rd respectively in dependability and safety. The folks on here are probably less than 1% of all the owners. I don't fault Lexus for a w/s that was one of many made from their supplier with a hiccup. They took one look and replaced it with a smile during my 'free' 10000 mile maintenance.
Old 06-04-10, 07:29 PM
LexBob2
LexBob2's Avatar
IMO, just plain bad luck is more of a factor with broken windshields than poor quality etc.
Old 06-04-10, 10:20 PM
Johnny
Johnny's Avatar
If you could validate your assertion with real facts rather than painting this issue with a broad and uninformed brush, it might be worth discussing or debating, but quite frankly you really did not add any substance to this thread, so...
Windshields undergo tremendous thermal and mechanical forming processes in manufacturing. There are very few companies in this world that can produce them, so car manufacturers tend to purchase them from this very compact supply stream. Just because it says Lexus, Toyota, Ford, Chrysler, Nissan, Aston Martin or Ferrari on the windshield does not imply they produce their own.
Occasionally, a few of them will fail due to residual thermal stresses, or manufacturing induced stresses either in handling or assembly. However, these rare events are so infrequent, they are replaced without question when/if it happens.
And no, they are not too soft...
Old 06-05-10, 04:04 AM
Joeb427
Joeb427's Avatar
I think windshields are thinner and lighter than in the past for less weight and crack and chip easier because of that.
Old 06-05-10, 05:06 AM
Cruiter
Cruiter's Avatar
Joe
Can you cite any articles to back that up? Or is there some fact you used to form that opinion?
Just curious.
Old 06-05-10, 05:09 AM
Joeb427
Joeb427's Avatar
Originally Posted by Cruiter
Joe
Just curious.
Well,just about everything else is made lighter to cut down weight.
Why not the windshield?No doubt it's thinner glass,IMO.
I'm in my 50's and don't remember all these chip and cracking problems on vehicles from the 60s,70s and 80's.Sure,it happened but not nearly as common as today.
I've only had windshields replaced on my 2000+ vehicles.A 2002 Grand Prix and 2007 Camry.
If I remember correctly,years ago,it took two guys to place the windshield in place on an install.Could be lack of the suction tool that is used today,though.
Old 06-05-10, 05:27 AM
redrocks
redrocks's Avatar
Agree, lighter and thinner reduces weight and increases the vehicle's MPG.
Old 06-05-10, 05:35 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Even if the windshield is thinner and/or lighter, I would not correlate it with Lexus being cheap or implementing cost cutting measures necessarily.
Old 06-05-10, 05:36 AM
Joeb427
Joeb427's Avatar
Could be the accoustic glass..
Windshields have gotten thinner and accoustic glass is lighter than stock non accoustic glass.
"The standard laminated glass windshield was first introduced for the safety benefit of providing occupant retention in the event of a crash. It also has proven vibration damping characteristics. Laminated glass consists of a 'sandwich' of a tough, polyvinyl butyral (PVB) interlayer bonded between two sheets of glass under heat and pressure. The PVB interlayer damps vibrations in the glass and, in automotive applications, produces a significant reduction in road and wind noise. Remarkably thin, the 'sandwich' ranges between 3.8 to 5.2 mm in thickness, depending upon its application, and weighs about 11% less than tempered glass of similar thickness. This weight reduction becomes important in overall vehicle design given OEMs' concern with vehicle weight.
http://findarticles.com/p/articles/m...2/ai_n9303485/
Old 06-05-10, 05:40 AM
Joeb427
Joeb427's Avatar
No cost cutting.I believe Lexus pays more for accoustic glass.Lighter like a lot of parts today for less curb weight for better MPGs for that GOV CAFE number.
redrocks
redrocks's Avatar
Windshields have gotten thinner and accoustic glass is thinner that stock non accoustic glass.
Yes, I was just looking up information on acoustic glass windshield! Wonder if it cost less to produce than regular windshields?
Quick Reply: Isn't Lexus RX windshield too soft?
