Heater issues
Old May 24, 2026 | 11:55 AM
262mbh's Avatar
262mbh
4th Gear
Default Heater issues
I have a long saga. Maybe my RX 350 2011 is ready to be terminated
here is the sequence of events
1) hvac controls takes several minutes to boot up
2) passenger side only blows hot air
3) air conditioner doesn’t work
replaced the HVAC amplifier
tried to replace the servo, that was mess an relized it can’t be done. Put it all back together. Tried to plug in a new servo and it didn’t work either
now i get hot air in the vents all the time.
I’m so frustrated, I wanted to keep this car running longer
thanks
Matt
Old May 26, 2026 | 05:53 AM
YeahThatsRight's Avatar
YeahThatsRight
my initial thought is a blend door actuator. yes they are a pain to fix but if you want to keep the car and its in good condition and well maintained then the cost to repair is worth it. even if you trade it for a similar vehicle with no cash upfront you may have issues with a new vehicle. the most economical IMO unless youre planning to get a new vehicle anyway because the repair isnt cheap at a dealer
Old May 26, 2026 | 06:01 AM
Clutchless's Avatar
Clutchless
Do you know if the A/C compressor turns on? Did you check the refrigerant charge? Did you check your coolant level?
If the compressor is not turning on, it may be that the flow sensor has become demagnetized with age, and there is a trick where you place a small magnet on the sensor to force the compressor to operate.
Many members have done this.
See below:
https://www.clublexus.com/forums/rx-...ac-issues.html
This link goes deep into the diagnostic procedure.
https://www.clublexus.com/forums/rx-...fo-inside.html
https://www.clublexus.com/forums/rx-...t-running.html
Old May 26, 2026 | 07:09 AM
salimshah's Avatar
salimshah
25 Year Member
Proper diagnosis is required. Is it worth spending money in doing the diagnosis, or just keep throwing parts till it gets fixed or throw in the towel is what you need to decide.
If you are open to speculations ... mine is that there is communication failure with or within the env-control function. I wish I knew more ... if such a module exists separately or is part of the ecu. Usually there is a communication protocol by which all functions talk to each other. [This conclusion/speculation is based on what you stated ... heavily biased on user input]
I would disconnect battery for 30min or so to clear out gremlins if any and see if the communication is reestablished.
Best advice from me would be:
Take the RX to some one who knows how the A/C communication works and let them diagnose the problem.
Salim
mengans
RX - 3rd Gen (2010-2015)
Dec 9, 2020 10:33 AM
AmaLex91
Oct 19, 2020 10:44 AM
Eklectika
Apr 22, 2019 04:56 AM
Jls160
Mar 29, 2019 04:36 PM
damndanny
Sep 17, 2017 01:38 AM
