Engine Noise
Old May 11, 2026 | 07:02 PM
popptj's Avatar
popptj
1st Gear
Default Engine Noise
I just bought a RX 350 from a Lexus dealer in Houston, with 70000 miles. I heard this engine noise and asked them to address it. They said it was normal, which I know it is not. I have a 30 day/1000mile warranty. Any thoughts what this might be? It is intermittent. Tks.
Edit: Ok, when I turn off the AC it goes away. Compressor clutch?
File Type: mov
Old May 11, 2026 | 09:52 PM
salimshah's Avatar
salimshah
25 Year Member
Test out another RX at the dealer lot side by side.
Also why would you insist on buying something that you suspect is bad from day1.
Salim
Old May 12, 2026 | 12:02 AM
carguy75's Avatar
carguy75
I would assume the noise is from an bad AC compressor clutch bearing.
Replacing an AC compressor clutch is not an hard repair, even DIY. However, it maybe cheaper to buy an new aftermarket compressor as opposed to buying just an OEM replacement clutch assembly.
I personally would just try to replace the clutch(aftermarket or OEM) on my RX350 if it goes bad, unless I have to remove the compressor from the car to change the clutch assembly then I would just go with an new aftermarket Denso one. Many times the AC clutch can be changed without removing the compressor from the car or opening the AC system.
Old May 12, 2026 | 05:23 AM
Clutchless's Avatar
Clutchless
Get an independent used-car inspection with written results. Tell them of your concerns about the air conditioning. If it is found to be bad, take it back to the dealer and demand repair or your money back.
You have a 30-day warranty.
auero
RX - 4th Gen (2016-2022)
Apr 4, 2024 12:07 PM
Eias12345
Dec 4, 2020 11:55 AM
brendanf
RC F (2015-present)
Mar 2, 2020 11:18 AM
MV2016
RX - 3rd Gen (2010-2015)
Jul 6, 2016 11:32 AM
stelars
12
Aug 12, 2012 11:57 AM
