Odd noise
Old Feb 29, 2020 | 07:02 PM
brendanf's Avatar
brendanf
Default Odd noise
Guys I noticed a strange noise today on my F. I have heard this noise with the engine running but never with the engine off. It literally sounds like an A/C compressor clutch engaging and disengaging. It made the noise several times just after shutting the engine off and the delay between hearing it got longer and longer. It eventually stopped. It is my understanding that the A/C compressor doesn't even have a clutch anymore on these cars so I am a bit stumped as to what could be causing it and if it is normal.. I have never heard it make the noise before with the engine off...
Any ideas?
Old Mar 1, 2020 | 10:07 AM
CinFulxgs's Avatar
CinFulxgs
It's normal, has to do with Evap system.... prob what it is.
Old Mar 1, 2020 | 10:50 AM
05RollaXRS's Avatar
05RollaXRS
Yeah, it is in the manual. Even my Lexus RX makes funny noises after being turned off. Something to do with emissions testing, I believe.
Old Mar 1, 2020 | 07:56 PM
CinFulxgs's Avatar
CinFulxgs
My daughters Camry did it once... probably a Toyota thing.
Old Mar 1, 2020 | 10:54 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
There's a vacuum pump testing the evaporative emissions system. Normally it starts 4 hours after you shut the car off.
Old Mar 2, 2020 | 07:30 AM
brendanf's Avatar
brendanf
I’ve seen the info in the manual regarding the EVAP test but that should occur hours after the car is shut off. Something like 5 hours.
This noise was happening right after the car was shut off and it was only running for a couple of minutes as I was only pulling it out of the garage. It was also VERY loud and metallic in nature. It did it about 5 or 6 times.
Old Mar 2, 2020 | 11:18 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
There's a one way clutch on the alternator drive. Maybe it's not happy. Maybe the belt tensioner pulley bearings are not happy. Pretty hard to diagnose from afar. No MIL or DTCs?
ichitaka86
NX - 1st Gen (2015-2021)
14
Sep 19, 2020 05:55 AM
PAVGR
Jul 17, 2013 10:47 AM
daryll40
Jul 10, 2012 05:44 AM
nihard
Jul 25, 2011 05:09 PM
sjgIS350
May 5, 2008 10:51 AM
