Thoughts on MAF cleaning and engine decor service
I have a 2015 RX350 base with ~115k miles.
What do folks here think of doing MAF Cleaning or engine "decarb" service? Worth it? Or wait until it runs poorly?
Car runs great and I want to keep it that way. I'm the 2nd owner; I bought it a year ago. I dearly LOVE this car and hope to keep it running a LOOOONG time.
Cleaning throttle body is the same. Clean it once every 50k-100k.
I just bought CRC Mass Air Flow Sensor Cleaner to clean the MAF sensor, and CRC Intake Valve and Turbo Cleaner to clean the intake system and valves.
Of course, I should have performed this cleaning before I removed the intake manifold and replaced the spark plugs—but it is what it is.
I have a 2012 4runner with almost 180k miles and a 2010 RX with less than 120k miles. I cleaned the 4runner MAF for the first time at 150k miles. looked fine. no performance difference and no issues. I then changed the pcv value for the first time after 170k miles, sounded just like the new one I had. I was going to do the same for the RX but with no performance issues or codes I don't think it's needed. the MAF isn't easy to get to , you have to remove a few pieces . the PCV valve is easy to get to but I just don't think it's needed but people seem to feel otherwise
If you engine has been well maintained and is running well already do not risk messing it up.
Of course, there are milder flushes—essentially just a higher concentration of the additives already present in the oil—that allow you to drive, for instance, 100 to 200 miles before changing the oil.
If you take the time to understand how it all works—look at the test results, and so on—there is absolutely nothing to be afraid of. You just need to use it wisely. Different engines—with varying mileage and other factors—require their own specific approach.
As for the MAF sensor: on the car that was throwing a MAF-related error code, cleaning it didn't help. On other cars where I performed the cleaning, I didn't notice any effect (though I didn't compare live data parameters before and after the procedure). However, cleaning the intake system *did* yield improvements; I am currently observing a reduction in fuel consumption.
If the engine does not need it(repair or service) sometime it is best to leave well enough alone.
Here is what happened to me a few years ago when I decided to change an oil pressure sensor that need not replacing because I was changing out the accessory belt that was blocking it. The front timing cover cracked while installing the new sensor that required an engine tear-down to replace the front cover. So I do not recommend messing with something on a car that do not need touching. Crap can happen anytime you work on car for whatever reason.
Here is what a simple accessory belt change turned into because I wanted to be proactive and touch something that did not need replacing.
