2015 lexus Rx350 code c1433 steering angle sensor.
Old Dec 19, 2025 | 03:47 PM
FrankFl1's Avatar
FrankFl1
Default 2015 lexus Rx350 code c1433 steering angle sensor.
Goodnight guys so i have this issue. I just did a engine replacement on a lexus rx350 fwd 2015. And im getting the SAS sensor error now. I tried hard reset again trough battery and redo procedure but its not doing anything. I called the dealer and they are quotin 280 just for the zero point calibration.
I have only a code reader not a scanner itself. Any cheap scanner that would be possible to do the calibration with? Thanks in advance
Old Dec 19, 2025 | 04:51 PM
Clutchless's Avatar
Clutchless
This problem was discussed in this older thread which was found by searching c1433 in the search box on the upper right of the main page. Hope it helps.
​​​​​​https://www.clublexus.com/forums/rx-...-any-info.html
I would try an independent Toyota specialist before going to a dealer.
Old Dec 19, 2025 | 06:47 PM
FrankFl1's Avatar
FrankFl1
Hey yeah i saw that thread but ended up pretty fast. Havent tried the pins with the clip but i dont know if the ob2 has the same numbers
Old Dec 22, 2025 | 10:26 AM
FrankFl1's Avatar
FrankFl1
Ok so on the update i took it to a shop with a scanner and the angle sensor is not sending any signal is stuck at 800 somth angle. Ill add the picture of the code im getting. And whenever you steer dosnt change at all.
Any help would be greatly appreciated
Now according t the guy i may have not plugged in something correctly. But as far as i know. The steering just bolts out. Thank you in advance.
Old Dec 25, 2025 | 04:27 PM
FrankFl1's Avatar
FrankFl1
Help anyone? I dont know what else to try.
Old Dec 26, 2025 | 03:56 PM
salimshah's Avatar
salimshah
25 Year Member
It seems you have done the mechanical side right.
I would suggest get hold of the electrical wiring to-from the sensor. Then make sure all connectors are connected properly. Be very careful if you end up using a VOM to ensure connections are correct as it might ignite the air bag.
Salim
Old Dec 28, 2025 | 09:45 PM
FrankFl1's Avatar
FrankFl1
Salim
Heyy. But why would anything electric would be bad if everything is connected righr. I didnt touch the steering columm. I just attached the bolt back on the bottom. Im gonna by an autel scanner for srs and abs reprograming with zero point calibration. Im just waiting on there end to see if its compatible with the lexus rx350. It seems to be that nobody has a diagram or even can refer a scanner that would do the job.
ramirez32385
ES - 7th Gen (2019-2025)
Sep 18, 2024 06:49 PM
symone
GX - 1st Gen (2003-2009)
May 27, 2014 11:28 AM
oslouie
Apr 23, 2012 06:31 PM
lexus114
RX - 1st Gen (1999-2003)
Jun 28, 2009 06:40 AM
esucaris1
Jul 23, 2007 10:03 PM
