Transfer Case Oily Bolt
Old Nov 22, 2025 | 12:40 AM
Mike03's Avatar
Mike03
5th Gear
Default Transfer Case Oily Bolt
Hey guys, I'm trying to figure out where did the oil coming from? And how can it be stopped?
Transfer case/passenger driveshaft - 2015 RX AWD 6-speed
Old Nov 22, 2025 | 02:25 AM
carguy75's Avatar
carguy75
Maybe the start of a bad axle seal that is flowing/weeping oil down over that bolt.
Just a guess from the image provided and location of the bolt.
If it is an bad axle seal then you will need to replace that seal to correct the leak issue.
Old Nov 22, 2025 | 05:03 AM
salimshah's Avatar
salimshah
25 Year Member
Clean it and go couple of inches above if you can. Then dry it out.
Leave the vehicle parked and check the next morning.
Put powder if the trace is harder to find.
Once you know the source then work on the remedy. At times you may have to consider the cost of repair and potentially put the repair of till it changes from bothersome to must fix.
Salim
Old Nov 22, 2025 | 10:26 AM
Maybe that's not the original plug? I thought it is supposed to have a dimple in the middle. Either way why not replace it and the gasket, I've had these plugs leak although I couldn't see anything wrong with them. Replacing both fixed it.
Old Dec 1, 2025 | 09:27 AM
Alex1989's Avatar
Alex1989
This bolt rests against the axle shaft bearing, preventing the axle shaft from moving. There's also a retaining ring between the transfer case and the axle shaft. The oil leak is most likely coming from the axle shaft seal.
Old Dec 1, 2025 | 10:57 AM
You are correct don't know what I was thinking, that is not a drain bolt.
TriniLex
RX - 4th Gen (2016-2022)
May 3, 2023 05:06 PM
Waynieboy
RX - 3rd Gen (2010-2015)
Apr 6, 2020 04:41 AM
bcg02
RX - 1st Gen (1999-2003)
Dec 19, 2011 09:18 PM
MPLexus301
Jul 17, 2007 01:04 PM
