Codes P0174 & P0171. Dealership is lost
Old Feb 23, 2024 | 06:16 PM
LaytonSparks's Avatar
LaytonSparks
6th Gear
Question Codes P0174 & P0171. Dealership is lost
I have a 2010 Rx350 that throws the codes 0171 & 0174 intermittently. The check engine light will come on along with the traction control light. Weird thing is the check engine and traction control light will periodically go off by itself without me clearing the codes. I took it to the dealership explained the issue and left it for 8 days. They went through all the testing that is required for those codes and found absolutely nothing. They replaced all gaskets related to the possible problem, did a smoke test and plenty of other diagnostic tests, they basically got to the point to where they were ordering parts and replacing then taking them off and returning them because nothing was fixing the issue. So I finally just picked it up because I was going on vacation and didn’t want it to stay there for two more weeks. Has anyone had this problem that they found a solution for?
Old Feb 23, 2024 | 08:13 PM
salimshah's Avatar
salimshah
25 Year Member
You are very lucky as they are accepting a return after installing part(s).
Lexus dealerships have trained mechanics and they have a regional expert who can be looped in to consult. I would say talk to the service manager.
If you are diagnosing by yourself, try reading live data. Some savvy member may be able to give you guidance.
Salim
Old Feb 24, 2024 | 01:34 AM
carguy75's Avatar
carguy75
Just a guess, but maybe an air/fuel ratio sensor is bad. I believe that bad air/fuel ratio sensors can trigger the two codes as well, however it is odd that both banks are bad at the same time. I would also check the wiring harness ground connections for any bad connections.
Personally I would check the intake manifold seals if nothing else solve the problem since a bad intake seal can allow un-metered air to enter the manifold pass the sensors and mess up the air/fuel ratio the ECU is measuring which can trigger the warning for both banks like in your case.
Old Feb 24, 2024 | 04:40 AM
RX in NC's Avatar
RX in NC
On a non-Lexus vehicle we own, P0171 and P0174 codes were resolved by replacing both VVT (Variable Valve Timing) solenoid O-ring seals.
Who is your dealership?
Old Feb 24, 2024 | 07:44 AM
LaytonSparks
6th Gear
I’ve been taking it to Johnson Lexus of Durham.
Old Feb 24, 2024 | 08:03 AM
LaytonSparks
6th Gear
The gaskets I know they replaced was the Plenum manifold and Throttle body, plus they replaced an oxygen sensor and they inspected and cleaned the connectors. I’m not sure if they inspected all other air/fuel sensors or connections though related to the issue.
Old Feb 24, 2024 | 08:14 AM
carguy75's Avatar
carguy75
Well, i am at a lost. The codes are generally cleared by replacing those items.
My next best guess is may be a bad ground connection(lose or broken wire) on the chassis.
Old Feb 24, 2024 | 08:35 AM
salimshah's Avatar
salimshah
25 Year Member
Very probable. Specially if there is not visible ground tap in between the engine and fire wall.
Salim
Old Feb 24, 2024 | 08:49 AM
Gerf's Avatar
Gerf
Your long term fuel trim is pretty high, the link below might be helpful for you.
https://www.clublexus.com/forums/rx-...4-codes-3.html
Old Feb 24, 2024 | 10:28 AM
LaytonSparks
6th Gear
Yeah I read his write up and solution, but the part that fixed his issue (Air intake control Valve) doesn’t seem to exist on the 2010 Lexus Rx 350. I guess Lexus changed the intake when they moved on to gen 3.
I appreciate the help!
Old Feb 27, 2024 | 07:27 AM
afpj's Avatar
afpj
Assuming the dealership ran the smoke test correctly, and ruled out a leak in one of the several vacuum hoses, have they looked at the MAF? Is there a CAI installed by any chance or a nonstandard air intake setup? The MAF is a PITA to change out because the windshield cowl has to come off, just like when replacing the intake manifold, so curious if they switched out or tested the MAF while the cowl was off.
Old Feb 27, 2024 | 08:50 AM
LaytonSparks
6th Gear
They did a smoke test, not sure how well, but it was done. There’s no mods done to it like CAI or anything like that, everything is stock Toyota/Lexus parts. The MAF was one of the parts that they ordered, replaced and then sent it back because it didn’t fix the problem.
Old May 25, 2024 | 11:05 AM
LaytonSparks
6th Gear
Default ***Update*** The issue has been fixed.
So after months of dealing with these codes popping up intermittently and the dealership not knowing what the problem is or even where to look I decided to take it to a hole in the wall mechanic shop, like every mechanic is working on cars while a cigarette is hanging from his mouth mechanic shop.
Dropped the car off and took an Uber home, 30 min later, got a call that they found out what the issue was and to pick up the part on the way back and they can fix it today.
When the dealership replaced the valve cover gasket they didn’t seat the gasket properly and that was the reason for the small air leak.
However I reached out to the Lexus dealership and explained what I found and they reimbursed me for the charges to replace the gasket.
Old May 25, 2024 | 11:28 AM
RX in NC's Avatar
RX in NC
Glad to hear that Johnson Lexus reimbursed you for their lousy work. Long-time-in-business, very knowledgeable indie shops are so much better than any dealership. The only reason I ever darken the door of a dealership is for warranty work or recalls.
Old May 25, 2024 | 04:12 PM
salimshah's Avatar
salimshah
25 Year Member
And the winner is CarGuy post #3.
Glad it got resolved and dealership owed up to their mistake.
Salim
seanmwple
Aug 23, 2023 05:44 PM
Birdy22
Dec 22, 2017 04:34 PM
Lexus0150
Nov 1, 2015 07:32 PM
ivnnln
Mar 6, 2014 05:32 PM
sealuvr52
RX - 1st Gen (1999-2003)
Jan 7, 2009 07:08 AM
