Changing Front Parking Brake Cable
Old Jul 16, 2021 | 09:04 AM
rplexusrp's Avatar
rplexusrp
Default Changing Front Parking Brake Cable
Hi Everyone,
My front parking brake cable is broken on my Lexus RX330, 2004. I changed the cables that come from the rear wheels to the middle of the car but I need to change the front cable. It seems a bit complicated since the cable goes inside the car from the bottom of the car and reappear right behind the foot pedal assembly. Does anyone know which panels should be opened to get access to this cable? and is there any instruction for this maintenance? Any information or picture can be very helpful. I searched online and didn't find anything. Thanks.
Old Jul 16, 2021 | 10:12 AM
iMSQ's Avatar
iMSQ
Has it broken outside or inside? Why don't you just connect the broken parts if it's outside?
Old Jul 16, 2021 | 10:37 AM
rplexusrp's Avatar
rplexusrp
It's in pretty bad shape, it broke right behind the foot pedal. I replaced all parts from the drum hardware to other two cables. Better to replace this one as well to make sure it remains reliable after all.
Old Jul 17, 2021 | 09:33 AM
Trebbor's Avatar
Trebbor
I don't know if the attached parking brake info will help you as it's for the 2007-08 RX, but maybe it's similar enough. Good luck.
Bob
File Type: pdf
Old Jul 21, 2021 | 10:42 AM
rplexusrp's Avatar
rplexusrp
Thanks for the help. I got the job done. Basically, the cable is right under the driver seat. So, you don't need to remove the center console to get access to the bolts that keep the cable in place. Just take the drive seat out and push the carpet back until you see the bold. These are two 10mm bolts that come off easily. The more difficult part of the job is to install the cable on the foot pedal assembly. For that, you need to take off the plastic cover under the steering wheel. Then you will have enough room to put the cable. Try to first install the cable on the assembly before going under the car to connect the cable to the equalizer. If you connect the cable to the equalizer first, you will find it extremely difficult to push the cable to it's position on the foot pedal assembly.
WylieKylie
Suspension and Brakes
Sep 20, 2025 11:01 AM
jpdavis423
14
Apr 27, 2022 09:35 AM
Satchem
RX - 3rd Gen (2010-2015)
Jun 14, 2021 08:24 AM
wing0
RX - 1st Gen (1999-2003)
May 31, 2021 02:39 PM
studio54
Jun 1, 2015 05:35 AM
