Tpms bypass
Old Feb 27, 2021 | 04:39 PM
Negative11's Avatar
Negative11
Default Tpms bypass
Hello all. I am looking to disable the tpms system on my 2007 Lexus Rx350. I check tire pressures weekly and dont want to deal with the light on in the dash. I have seen ways to do it on other Lexus vehicles but mine has different colors on the plug going into the tpms module. I have attatched a picture of the plug. Any help is greatly appreciated.
Old Feb 28, 2021 | 09:32 AM
iMSQ's Avatar
iMSQ
Old Mar 26, 2021 | 10:29 AM
EDness's Avatar
EDness
Did you ever figure out how to disable it?
Old May 12, 2021 | 10:24 AM
fpatt's Avatar
fpatt
Default Where is the location of module
Where did you find the module. Do you have a pic of the location of the module. From my understanding some has the blue and green wire connected to disable the light on the dash.
Old May 15, 2021 | 02:58 PM
rashaunny's Avatar
rashaunny
Did you accomplish the disable without removing the light bulb?
Old May 16, 2021 | 01:02 AM
LewisLou's Avatar
LewisLou
I would also like to know
Old May 17, 2021 | 09:00 AM
mandyfig's Avatar
mandyfig
You will need Techstream to correctly disable your TPMS. Cleanest way to do it. Or go to a Toyota dealer and have them do it, however since it is a safety item, they might say no.
Old Jun 22, 2021 | 07:17 PM
Felix's Avatar
Felix
So whats the story of which two wires need to be spiced together for the rx? Blue wire & ? one?
Old Jun 27, 2021 | 08:16 PM
Felix's Avatar
Felix
Bought 4 new sensors to have Discount tire to install w/ new tires.....One of the sensors was mispackaged, so they installed the three I had w/ a still good one that worked....whoa no more tpms light on & the new tires work great as well.......
Old Jun 21, 2022 | 11:06 PM
MattRX's Avatar
MattRX
I tried but was unsuccessful in my attempts to bypass the TPMS the conventional method (splicing the two wires). Unlike most of the other Toyotas, our cars use Canbus for the TPMS instead of a simple pink "IND" wire that goes right to the idiot light and will turn off with 5V. Lots of hours of reading various other wire diagrams and I have decided to give up on that method because it is testing my patience. The GS350 and IS350 seem to have the same situation going on as well.
I'll probably just find out which wire goes to the light into the dash itself and kill power there. Will post my findings.
Old Jun 23, 2022 | 07:14 PM
Felix's Avatar
Felix
Or just remove the bulb, Matt......Little more $, but I just replaced three of the sensors......
Old Jun 23, 2022 | 07:18 PM
MattRX's Avatar
MattRX
I think it may be an LED bulb, all of my old Highlander’s dashboard lights are so I bet the RX would be the same.
I would definitely consider the sensors if they weren’t so expensive, were serviceable and if I didn’t have to swap between two sets of rims/tires.
j1ffrey
NX - 1st Gen (2015-2021)
Sep 8, 2022 01:08 AM
Tannerkra
Jun 23, 2021 07:51 AM
pebbleh
RX - 4th Gen (2016-2022)
Jul 23, 2017 05:54 PM
Zayarik
Mar 8, 2013 11:36 AM
