Replace master key / master key programming
Old May 8, 2021 | 04:51 PM
uksparky's Avatar
uksparky
I just got a new key made 1010 keys ...read my post, just take pictures of your key send em off with payment and get a new square type flip key within a week for under 30 bucks.... or you can pay a locksmith 100 bucks
Old May 10, 2021 | 09:57 AM
Mkot9's Avatar
Mkot9
Default I found it....
So I found the master key. I KNEW the LaZBoy chair ate it, it eats everything, but it didn't give it up until I had spent three hours stressing and searching and right before I was going to dig up 6 feet of underground gopher fencing I had put down the day before! Honestly, I stressed and searched so hard that yesterday my body felt like I played a game against a pro football team!!!
Thanks, as always, for your help. I think I'll look into the, oh darn, eternity/forever/perpetual, that key some of you were talking about, plus a very long, thick, plastic chain to put the key on!!!! Thanks
Old Aug 23, 2021 | 12:17 PM
maoslarx33's Avatar
maoslarx33
9th Gear
New purchase this month for me, Used car dealer only had the grey valet. Went to the Lexus dealer, was given the story that without a master key, they would have to reseed the ECU at $600 and then they would sell me a master key cut and programmed. Service advisor also said that they could not give me the key code even though I could proof ownership of the vehicle. Went to Home Dept. to cut a spare of the valet, they said they could not because laser cut needed. Went to ACE Hardware, they said it is their policy not to cut a key unless I have the master key. While driving home, I said a locksmith storefront, the person in there said they have a mobile guy, called him and he met me at the shop. I told him that I did not have a master key or the key code, he said no problem. He removed the driver's side door lock and took out the cylinder and showed me the key code. He made a master key, programmed it and I heard the car alarm for the first time since I purchased the vehicle. He also cut another key for me that I had purchased from Ebay. All for just under $200.
After reading countless threads on keys and replacing, it not that expensive, 1 screw to remove the driver door lock. Not waste your money with the nonsense the dealership is telling you about reseed if you don't have a master key and they refuse to give you the key code.
2004 RX 330 was my purchase,
Old Aug 25, 2021 | 11:54 AM
Vincenze's Avatar
Vincenze
Was the access to the door lock cylinder that easy? I need the key code as have only one wrecked key with dead transponder. RX400H killed by a recovery guy that twisted the ignition over and over waiting for the car to fire up like a normal ICE.
Old Aug 26, 2021 | 06:21 AM
maoslarx33's Avatar
maoslarx33
9th Gear
The locksmith removed a rubber tab, and it was 1 screw to remove the lock cylinder on the driver's door.
Old Nov 16, 2021 | 11:21 AM
GXMeister's Avatar
GXMeister
Default 2008 RX350 Key Fob Programming
I have just purchased my wife a 2008 RX350. However, the dealer only had one master key. I purchased two keys online then had them cut thinking I could just program them like I did with our 2001 RX300, but have had no luck.
I have searched the Gen 2 site and cannot find a definitive answer if I can self-programmed this key fob... lots of misinformation on Youtube and I have tried several techniques with no success.
Dealer wants $65 to program. Is this really my only option?
Old Nov 16, 2021 | 12:43 PM
iMSQ's Avatar
iMSQ
IMHO, $65 is not too much
https://www.clublexus.com/forums/rx-...aster-key.html
Old Nov 16, 2021 | 01:34 PM
GXMeister's Avatar
GXMeister
Originally Posted by iMSQ
Perhaps, but I am looking for the answer to my question. Is there a way to DIY program my RX350 Key Fob like I was able to do for my RX300?
If not, then the dealer will be my only reliable option.
Old Nov 16, 2021 | 03:09 PM
frankymenz's Avatar
frankymenz
Batteries plus programs keys too. Many Autel scanners will or someone with techstream. I see you're in Minnesota, you could post a thread in your local state forum on Club Lexus, maybe someone is near you with a techstream?
Frank
Old Nov 16, 2021 | 05:29 PM
Margate330's Avatar
Margate330
Have you tried the RX300 method?
If it works it would be an awesome discovery.
A while back a member helped me swap my ECU and pair my keys and from what I understand the keys give off a frequency or something that the key transponder accepts or rejects. Also found out when I swapped my ECU I was pairing the ECU to the key transponder amplifier and the transponder amplifier is what holds the key info or something.
Link to ECU swap with key path to ECM: https://www.clublexus.com/forums/rx-...preciated.html
Been wondering a long time what make up the parts of this key.
I know there is a:
1) metal key blade
2) Battery powered FOB transmitter for wireless unlock
3) Something that the key transponder recognizes but only when very close like when keys are in ignition- but what is this piece?
And I may be missing something and got this all messed up so if anyone knows plz add...
Old Nov 16, 2021 | 05:36 PM
frankymenz's Avatar
frankymenz
I should ask, are these a smart key with a push to start button or is it a key you insert into a lock cylinder and turn to start the car?
Old Nov 16, 2021 | 06:28 PM
GXMeister's Avatar
GXMeister
Yes... did not work.
Old Nov 18, 2021 | 09:49 PM
Margate330's Avatar
Margate330
Hopefully someone will figure out a DIY way.
I don't think it's fair for Lexus to make the customer dependent on them to program a key fob.
As far as I know the "transponder key coil" communicates to the "Transponder key ECU" as seen below.
Old Nov 19, 2021 | 06:32 AM
Margate330's Avatar
Margate330
If someone can figure this out plz let us know and post a "step by step" that works.
I haven't spent much time looking at it but it's technical and needs simplified.
Attached for Gen 2 RX350
File Type: pdf
Old Nov 24, 2021 | 10:07 AM
GXMeister's Avatar
GXMeister
Big disappointment today. After having spent money to have the keys which I purchased from a reputable seller on Ebay, the dealer told my wife they were not programmable. I am a bit skeptical since I had purchased an RX300 Key Fob from this seller which I programmed myself.
I have notified the seller on Ebay to learn whether or not they can disprove the dealer's claim. I find it hard to believe a reputable seller would sell keys that can't be programmed, but we shall find out.
However, it is all mute now, since my wife spent $200 on the replacement before letting me know what was going on.
