Hi Guys,Noticed today that my nearside wing mirror isn't fully dipping when I put the car into reverse, it moves very slightly but not as normal.. The mirror seems to be functioning properly when I move the mirror switch to 'L' and use the directional toggle switch, but not when the car is put in reverse.
Any ideas?
Any ideas?
Felix
close
- Join DateDec 2019
- LocationThe Jet City
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:608 Times in 523 Posts
To have both mirrors dip down when in reverse, the switch needs to be in either all the way to the left or right, if you leave the switch in the center it won't dip down in reverse.
Yeh I know that Felix. AS I said the mirror dips slightly whereas the offside mirror dips as it always has...
05ls430518
close
- Join DateNov 2017
- LocationNew York
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:268 Times in 223 Posts
Quote:
He was just trying to help you out.......and your mirror motor is busted you need a brand new oem mirror or replace the mirror motor, easier to just buy an mirror assembly.Originally Posted by Burroo67
...and I appreciate the help, but my original post mentioned the fact that the mirror works normally when in the left position (RHD Car) but not when put in reverse, so the motor still works but there is a problem with it dipping when in reverse. I discovered not long after buying the car 22 months ago that the mirrors would only dip in reverse gear when not in the neutral position. Someone has suggested that I remove the mirror and give the inside workings a right good clean and treat with loads of WD40 - I just wanted to know if any of my North American fellow owners had experienced the same problem. I meant absolutely no offence whatsoever to Felix.
joedaddy1
close
- Join DateDec 2005
- LocationOrange County
Liked:214 Times in 168 Posts
Cant you set the reverse setting?
Try adjusting the mirror to your liking while in reverse.
Once set, go back to park.
When you shift into reverse again, it should be on your new setting.
Thanks Joedaddy1, will try that before I start dismantling the car!!
