Felix
close
- Join DateDec 2019
- LocationThe Jet City
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:609 Times in 524 Posts
Curios to hear what transmission fluid you guys use. I'm wanting to swap out the filter as well as the fluid. I see there's quite a bit of 411 regarding WS vs non certified oils. I wouldn't think, just because a oil company didn't go thru the process of getting their product Toyota certified that it wouldn't work & perform the same if not better. Lot of 411 on tacomaworld. Like to hear what you guys are thinking/thoughts. I was originally going w/ the toyota fluid, but now as all this 411, I believe I'll use the maxlife.
I would stick to WS fluid, it's not that expensive (takes less than 4 qt for drain and refill).
I'd prolly ask this question here: https://www.bobistheoilguy.com/forum...ans-brakes-p-s Maybe do a search there for RX350 ...
Lexuswiz
close
- Join DateSep 2016
- LocationChicago, IL
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:183 Times in 169 Posts
Valvoline MaxLife Full Synthetic ATF on all of my vehicles with a standard AT. My Scion and NX are CVT and low mileage so when those are due, I'll see what my options are. I'd also go MaxLife if it is compatible. No issue so far and my RX shifts smooth.
Margate330
close
- Join DateApr 2019
- LocationFL
Liked:1,610 Times in 1,293 Posts
Quote:
While we are on the subject if it is ok with the OP if anyone has used the Maxlike synthetic on the RX330(Type T-IV fluid) with success over many miles too plz share.Originally Posted by Lexuswiz
Lexuswiz
close
- Join DateSep 2016
Changed my RX330 around 73K miles when I got it used, pushing 110K now. Zero issues. My last Camry went through 3 drain and fills and still ran when I sold it at 190K. I have no issues to report of, but I have changed the trans fluid consistently with new filters each time.
Felix
close
- Join DateDec 2019
Quote:
I had a look at the back of a gallon jug of maxlife & it said it'll work for your T-IV fluid. + on top of it, its full synthetic vs dino oil.......Originally Posted by Margate330
Margate330
close
- Join DateApr 2019
- LocationFL
Quote:
Full synthetic sounds good to me but don't know if compatible with WS type for your car tho.Originally Posted by Felixtheca
Since I've already done 3 drain and fills maybe I'll drop the pan and take a look and then do a total fluid change by dropping the transline with the Maxlife
so I have all new.
Felix
close
- Join DateDec 2019
so I have all new.
It also said WS as well as others....Originally Posted by Margate330
Full synthetic sounds good to me but don't know if compatible with WS type for your car tho.Since I've already done 3 drain and fills maybe I'll drop the pan and take a look and then do a total fluid change by dropping the transline with the Maxlife
so I have all new.
05ls430518
close
- Join DateNov 2017
- LocationNew York
Liked:268 Times in 223 Posts
Dont mix fluids its how you get a broken transmission also use type t-iv its what Lexus says is supposed to be in the trans I use this with 0 problems.
close
- Join DateOct 2019
- LocationOhio
Liked:1,800 Times in 1,389 Posts
Max life will work and do a better job, it's also the same stuff autozone and advance auto brands as their "multi vehicle" and "global" fluids respectively. It works in literally everything I've tried it in that it claims to, only ones to NOT use it in are ZF and ATF+4 trans.
Felix
close
- Join DateDec 2019
Bought a gallon of Maxlife, wix filter & 2 qtrs of Royal Purple for the diff's....That should keep it rolling for awhile......
