Engine bay smell from vents
Old Feb 9, 2018 | 07:39 AM
Claassen's Avatar
Claassen
Default Engine bay smell from vents
On my 2008 RX350, with fresh air turned on, I get "hot engine" smell from vents. Not gassy, just smells like under hood normal smell. But its coming through the vents. On recirculation mode, no smell is present. Any ideas?
Old Feb 9, 2018 | 08:39 AM
RickC5's Avatar
RickC5
I'm not trying to be funny, but something's broken--likely a seal or weather-stripping--somewhere. Lexus & Toyota usually do a reasonable job of sealing off the engine compartment & the associated smells from the vents. I would look around under the hood, back by the firewall & if you don't find/fix it, get ready for a trip to the dealer.
Old Feb 9, 2018 | 08:54 AM
Claassen's Avatar
Claassen
Default Engine bay smells
I'll give that a look! Thanks!
Old Feb 10, 2018 | 03:29 PM
Mesquite77's Avatar
Mesquite77
Be careful about going to dealer, there is a lot of HVAC stuff tucked under the dash, and it requires the whole dash, steering column, basically the entire front inside of car to be removed to get at it. (Google RX350 replace expansion valve on youtube for some horror pics) Just a heads up, hope the problem is on the engine bay side.
Old Feb 12, 2018 | 06:25 AM
Claassen's Avatar
Claassen
I learned a trick from a body shop friend of mine. I put a small (3/8") foam round "rope" into the main long gasket sealing the back of the engine bay. This expands out the gasket for better sealing. I think its better, but the smell it still there. All the gaskets seem to be in place... Thanks for the info, I'll keep working on it!
RadlerCF
Jul 24, 2017 05:43 AM
lantash
Aug 25, 2016 04:06 PM
Fixman
Aug 3, 2015 12:45 PM
bkempf7
May 11, 2011 01:02 AM
NateInJapan
Performance
Aug 2, 2002 05:00 PM
