Drive belt replacement.
Old Nov 1, 2017 | 03:51 PM
DriverDad's Avatar
DriverDad
Default Drive belt replacement.
When do you guys typically replace the drive belt. I have a little over 135,000 miles on our 07 RX350 and the Lexus specialty shop in my area today said they don’t really see these belts break and normally only replace them if they are doing other work and it’s bascially free labor to repair. They didn’t suggest replacing it at this time.
Do you guys agree with this? 135k on a belt seems like a long time. I don’t want whoever is driving the car to get stranded somewhere.
Old Nov 1, 2017 | 03:59 PM
Lexuswiz's Avatar
Lexuswiz
Since the serpentine belts are so cheap and easy to replace, I try to replace them around every 60K to 80K intervals on all my cars. When I did my timing belt on my RX I did both drive belts with it (not sure if the 350 uses one or two like the 330) which cost me about $30 for both (OEM Toyota).
Old Nov 1, 2017 | 04:04 PM
RXGS's Avatar
RXGS
Replaced mine at 100k with a gates belt, didn’t look like it needed it, but didn’t look fresh either. For how easy it was and how cheap I figured why not
Old Nov 1, 2017 | 05:23 PM
2for1's Avatar
2for1
Replace it. It's cheap. Stick the old one in the rear compartment in case you need a spare.
My idler pulleys are making noise at 140K so I'm replacing those also.
Old Nov 1, 2017 | 06:21 PM
BlackLexRX's Avatar
BlackLexRX
I just replaced mine at 83k. Again, looked worn but intact. I wouldn't go over 100k on any car with one.
Old Nov 2, 2017 | 07:53 AM
nwfsnake's Avatar
nwfsnake
I replaced mine when I did the spark plugs at about 120K. Both belt and plugs looked pretty good for that many miles on them!
Old Nov 2, 2017 | 04:35 PM
DriverDad's Avatar
DriverDad
did you do it yourself?
Old Nov 2, 2017 | 06:00 PM
RXGS's Avatar
RXGS
Yes, very easy I found the DIY on toyota nation I think, but that was 2 years ago so might be one on here now
Old Nov 5, 2017 | 06:04 AM
FactoryRX's Avatar
FactoryRX
Could anyone post a link for the DIY for timing belts replacement ? I should do it soon...
Old Nov 5, 2017 | 07:05 AM
DennisMik's Avatar
DennisMik
The 350 engine does not use a timing belt, it is a chain that does not need to be replaced.
The only belt is the one that runs the alternator, a/c compressor, etc.
ThumperPup
13
Jun 9, 2014 08:02 AM
p0lo8
Performance
19
May 23, 2012 11:52 PM
sallydrive
Mar 3, 2012 10:18 AM
LeXuSrAcIn
RX - 1st Gen (1999-2003)
Oct 23, 2006 08:00 AM
LexGsBoi
Performance
Apr 19, 2004 11:08 AM
