2005 RX330 Air Conditioner codes
Old Sep 2, 2017 | 09:21 AM
MGonzales's Avatar
MGonzales
Default 2005 RX330 Air Conditioner codes
Started the RX330 this morning and no air was coming out of vents, So when I got home I let the car cool down check coolant and both fans turn on. I adjust the air condition setting and seems that compressor kicks on but no air flow..so I held the recirculation button and auto button since A.C. and Nav are together and got codes 21 and 24 ...I took RX330 outside since on another forum it read solar system solenoid and re-held the recirculation button and auto button since A.C. and Nav are together and got codes 00 but still no air flow through vents, as I moved RX 330 to back into garage I got codes 21 and 24
where can I find the codes info at ?and what do i need to do from this point to fix it or could it be the fan? any assistance is greatly appreciated
Old Sep 2, 2017 | 10:11 AM
5W40's Avatar
5W40
check this may help
https://www.clublexus.com/forums/gx-...code-24-a.html
if only no air flow I may test blower motor first, has better with Techstream scan A/C system for errors.
Old Sep 2, 2017 | 05:09 PM
MGonzales's Avatar
MGonzales
I spent the afternoon trouble shooting with a lexus tech he stated If you are getting no airflow from the vents or defrost vents or the floor vents no matter what setting the fan switch is on then the blower motor has failed. He had me confirm it by checking the 7.5amp heater fuse inside. The vehicle is driveable and it won't over heat..will order part and keep all posted
Old Sep 2, 2017 | 10:11 PM
5W40's Avatar
5W40
Highly doubt the root issue is a heater fuse blown, but check two fuses no hurt at first.
I doubt the blower motor regulator resistor is shot which may cause fuse blown or may just dead itself [fuses are fine], if so then either blower motor or blower resistor will need replaced.
my
MaxS
Jul 25, 2018 02:39 PM
RaheelAmi
May 26, 2014 06:31 AM
teefbee
Jul 4, 2011 11:40 AM
airtraffic
Jun 5, 2011 09:36 PM
sherylking
Oct 3, 2004 11:26 PM
