Reverse Camera - No Picture fault
Old Aug 24, 2017 | 10:28 AM
Fluffymug's Avatar
Fluffymug
Default Reverse Camera - No Picture fault
I seem to have picked up an issue with my reversing camera.
When the car is placed into reverse I no longer receive the feed from the camera. The feed does not show the camera feed (instead some jumbled colours - but nothing recognisable as a visual feed) but does show the augmented parking lines.
The head unit display functions correctly in all other modes.
When the car is placed in reverse I have the reverse lights active - I believe this rules out the fuse that feeds the camera and reverse lights.
I suspect this would be something a Lexus dealer would charge me an arm to replace!
I tried today to gain access to the camera unit - but was unable to figure out how I should do this? I was hoping to confirm that all the wiring at the camera unit was in good order.
Old Aug 24, 2017 | 03:30 PM
tomr51's Avatar
tomr51
i would guess camera is at fault. everything is switching correctly as per your description.
Old Aug 24, 2017 | 11:26 PM
Fluffymug's Avatar
Fluffymug
TOMR51 - Many thanks.
I would like to gain access to the camera unit and check its wiring. And should that not fix it be able to buy and fit the part myself (saving a bit of money from the dealer).
Does anyone know how to gain access to that area of the rear door?
Cheers
Old Aug 25, 2017 | 04:44 AM
daddiojigg's Avatar
daddiojigg
i have a 2007 400h and i don't have these parking lines.Ever.
Old Aug 25, 2017 | 03:36 PM
tomr51's Avatar
tomr51
an ebay ntsc camera (<$10) will work. You need to find 1 you can mount, or you can re fit into the OEM housing
phildogbph
GX - 1st Gen (2003-2009)
Jul 6, 2020 09:17 AM
Afiadata
Mar 7, 2019 06:16 PM
norseman76
Feb 17, 2019 06:41 AM
FatherTo1
Jul 21, 2016 10:32 PM
RookieLEX
Jun 29, 2016 02:43 PM
