Sway bar end link replacement?
Old Aug 15, 2017 | 06:59 AM
jmu2004's Avatar
jmu2004
Default Sway bar end link replacement?
My 2005 RX330 with 165k on it has developed a pretty loud clunking coming out of the rear passenger suspension. More often than not in Toyotas, this is a symptom of a bad sway bar end links. The struts were replaced at around 130k and the ride is fine, but I do notice body roll which also points to worn out end links. I can also manipulate the end links by hand, which I shouldn't be able to do.
Has anyone done this repair? Anyone with an older RX will run into this problem eventually....Seems simple, but just looking for any tips.
Old Aug 15, 2017 | 09:34 AM
thomas1's Avatar
thomas1
Very simple job. parts available everywhere including Rock Auto. Might need an open end wrench with allen wrench to hold link end when tightening or removing.
Old Aug 16, 2017 | 05:13 PM
RXGS's Avatar
RXGS
If the Allen key doesn't work, use vice grips and a ton of PB blaster. Also, make sure both tires are off the ground, that way the sway bar isn't twisting
Old Aug 17, 2017 | 08:12 AM
jmu2004's Avatar
jmu2004
Good advice.
I did the rear last night, and it was super easy. I had soaked the bolts in deep creep in the morning, which helped. I still needed the breaker bar to get things loose before using the allen key, but after that it was smooth sailing.
I also replaced the sway bar bushings, which I would recommend.
Anyway, the noise seems to be gone and the body roll is diminished. Can't wait to get to the front!
Old Aug 28, 2017 | 06:53 AM
jmu2004's Avatar
jmu2004
Just did the front, and that was a bit tougher than the rear due to the area being more crowded. Still pretty easy though..
If your RX feels loose or "floaty" through corners, go ahead and do this repair. My ride quality is great again, and turns/cornering are noticeably tighter.
I think my clunking noise is gone too, but I don't want to jinx it!
Overall, good/easy/cheap repair for a high mileage RX. Just turned 165k and still loving the old girl.
Old Aug 28, 2017 | 04:46 PM
Lexuswiz's Avatar
Lexuswiz
In my experience with Toyota/Lexus' from the Rust Belt states, the fronts will be very hard to remove without a torch. On every Toyota (I've done 3) I've done and my RX330, the fronts were so rusted that the allen key stripped halfway and I had to angle grind the nuts off. But this is using only PB blaster the day before and just sockets and allen keys. PITA but worth it. Had I know to use a torch (I forgot every time), it may had made it easier. Not an issue if the bolts are free of rust.
Old Aug 28, 2017 | 08:51 PM
ukrkoz's Avatar
ukrkoz
I had to clamp vise grips super tight on the back of OEM link, to loosen the nut. Nut is apparently pinch nut as it took me cheat pipe to undo it. And I do not live is salt belt.
I am frugal. I installed $26 ones from O'Reilly. They came with zirks and I packed them with grease. Plus, life time warranty. Can't beat warranty and price. They are so tight I had to take channel locks to stud to position it properly.
I don't care if it's OEM or not. Many cheap aftermarket parts actually last longer than OEM $$$$$$$ ones.
Old Aug 29, 2017 | 06:47 AM
jmu2004's Avatar
jmu2004
I'm not in the rust belt either (though this car has seen plenty of snow being in VA and WVA for skiing), but the front driver's side was heavily rusted. Really the only rust I could find on the undercarriage...
ISFLexy
Suspension and Brakes
Apr 5, 2018 05:14 PM
NikonGuy
Apr 21, 2016 07:43 PM
lexusben
25
Jul 12, 2015 06:24 AM
VTsuckah
Feb 13, 2015 06:44 AM
