Broken Key FOB Shell- Repair Solution
Old Jan 14, 2017 | 09:41 AM
05RX330AWD's Avatar
05RX330AWD
Default Broken Key FOB Shell- Repair Solution
Learned the hard way as part my key fob shell fell to the floor of the SUV when turning the key in the ignition.
JB Weld Plastic I used previously successfully on a expensive camera which a part was broken & obsolete.
I carefully spread some JB Weld Plastic in the inner & outer part of the fob shell where it was cracked, now it can be lightly sanded & painted.
Stronger than new.
The photo shows the JB Weld Plastic is a light grey when cured although 24 hours dry time is recommended for rough use.
Hopefully this will help someone in the future.
This is a great site, extremely helpful for first time Lexus owners as myself !!!
The finished repair project in second attachment, the battery can be changed.
Attached Thumbnails Broken Key FOB Shell- Repair Solution-keyfob.jpg   Broken Key FOB Shell- Repair Solution-keyfob2.jpg
Old Jan 14, 2017 | 02:19 PM
RedGemini's Avatar
RedGemini
I bought a replacement flip key, cut, on eBay for $22. I just installed the fob guts into it and it works perfect.
Old Jan 14, 2017 | 03:21 PM
05RX330AWD's Avatar
05RX330AWD
I suppose the difference is I paid $0.00 & waited about 20 minutes to be able to use it again.
I am confident it is much stronger than before although I'm using the FOB Key only to remotely open & lock doors & tailgate.
Especially here in the Great White North (Canada) with freezing temperatures & the unpredictable usually happens.
I'm using the other key for the ignition.
Old Feb 11, 2018 | 10:52 AM
YotaMD's Avatar
YotaMD
Former Sponsor
FYI, I made a solution for this after breaking two brand new ones right after buying my Land Cruiser (same key). I haven't had much traction getting the word out in the Lexus crowd, but the Land Cruiser and LX470 community has loved it.
Check it out:
http://yotamd.com/products/key_fob/Titanium3button.html
Attached Thumbnails Broken Key FOB Shell- Repair Solution-titanyoutubecover.jpg   Broken Key FOB Shell- Repair Solution-dscf0554.jpg
Old Feb 11, 2018 | 02:20 PM
ToledoRX's Avatar
ToledoRX
Yes, I had the same problem with my keys (the outer plastic case cracked apart), except instead of dropping the keys, the case cracked because I was turning on the ignition with way to much torque.
Old Feb 11, 2018 | 04:55 PM
cdnewton's Avatar
cdnewton
I spent about $10 on this product from Amazon. It isn't as well made as the yotamd referenced above, but similar idea.
https://www.amazon.com/gp/product/B01BCQVRZM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01BCQVRZM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Old Aug 14, 2018 | 07:52 PM
ToledoRX's Avatar
ToledoRX
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Tried this out and the replacement shell fits and I was able to get the metal key tip and alarm transmitter to fit inside the replacement shell.
You may need a pair of pliers to remove the remaining bits of plastic that was insert molded over the key off though.
Old Aug 15, 2018 | 08:39 PM
professorm's Avatar
professorm
The back cover on mine broke over the weekend. I ordered a new OEM back cover from eBay and installed it today’s.
Old Aug 16, 2018 | 09:40 AM
mandyfig's Avatar
mandyfig
There was a post here someplace that will send you a cut key FOB, am sure you have to submit proof of ownership. Anybody remember?
semar
Jun 21, 2016 05:56 AM
Inzane089
Oct 18, 2011 04:30 PM
Glendokid
RX - 1st Gen (1999-2003)
Sep 23, 2010 06:48 PM
Justakid
Maintenance
Jun 24, 2009 06:33 PM
