HELP! help me diagnose the real problem...
Old Oct 19, 2019 | 07:50 PM
BlackLexRX's Avatar
BlackLexRX
This is bad compliance bushings, otherwise known as the lower control arm bushings. When you said you felt it worse while hitting the brakes makes me confident about this. Very common for these to fail on RX's. Have your trusted indy check this or take to the dealer for an estimate. This is an either semi difficult repair to do DIY, or a costly one to have done in a shop as it requires engine mounts to be loosened or removed so the engine can be jacked up just a little for removal. Typically I only use/advise OEM, but in this case try and source polyurethane bushings.
anwallac
Sep 15, 2011 09:17 AM
scooters23
Sep 16, 2010 11:01 AM
MotoX
Wheels, Tires & Brakes Forum
Apr 25, 2009 01:14 PM
2JZGE
IS - 1st Gen (2001-2005)
38
Oct 5, 2002 02:39 PM
VQT
Jan 10, 2002 05:58 PM
