Remove cluster??
Hi all are there any DIYs that I am not finding? Or has anyone done this and can give me a brief run down?
I'd like to cover up the AFS OFF light like in this DIY.
https://www.clublexus.com/forums/showthread.php?t=625595
Just thought I would give an update on this. I figured out how to remove the cluster and believe it or not it’s very easy.
Step 1) Remove Cluster Bezel – Held in with clips if you move the steering wheel all the way out and down and give it a good tug (making sure not to break it) it will come loose
Step 2) Remove four screws holding cluster in place
And you’re done. I ended up covering the AFS OFF light with electrical tape just like in the above DIY since my lights seem to be aimed perfectly so I don’t see the need to pay $300+ right now. Also since I just mounted my winter rims and tires, so I threw some electrical tape on the tire pressure light as well. I prefer to use the old fashioned way to tell if a tire is flat, over paying $$ for it. The best part is because the cluster glass is tinted, even if you try to, you can’t see the tape on there.
1JZPWRD
Jun 21, 2017 10:17 PM
R1R
May 9, 2012 11:23 AM
