Brake flush fluid question ?
Old Mar 12, 2013 | 08:52 AM
99magna's Avatar
99magna
Default Brake flush fluid question ?
Hi Guys,
I want to use ATE Super Blue Dot 4 brake fluid to do a complete brake fluid flush on my 2009 RX 350 . My question is it okay to use a Dot 4 instead of Dot 3 per the manufacture ?. Thank you in advance.
Old Mar 12, 2013 | 09:15 AM
RX330inFL's Avatar
RX330inFL
Yes, you can use DOT 4 without issue. Though, you will not really see any benefit as your RX is not going to see any significant track time to generate the heat this is designed to handle. A stock quality synthetic DOT 3 or DOT 3/4 at a fraction of the price will suffice.
Old Mar 12, 2013 | 09:22 AM
GoGiantsNJ's Avatar
GoGiantsNJ
What is the intervals? Every 30k?
Old Mar 12, 2013 | 10:15 AM
Rainbird's Avatar
Rainbird
Yes, change the fluid every 30K
Old Mar 12, 2013 | 11:31 AM
RX330inFL's Avatar
RX330inFL
The interval is 24 months or 30K miles. Personally, I deal with this when I am replacing pads whenever that is necessary.
BTW, brake fluids are hygroscopic -- meaning it absorbs water. You can purchase a tester or test strips to check for moisture levels. However, unless you have a need to do this on a regular basis with a number of vehicles it would be perhaps more cost efficient to ask a service shop to check it for you.
Old Mar 12, 2013 | 03:10 PM
Adamjeeps's Avatar
Adamjeeps
I used Super Blue on mine before I traded it. Worked just fine. I used speedbleeders to make it an easy one-man project. http://www.speedbleeder.com/
Old Mar 12, 2013 | 08:14 PM
RX330inFL's Avatar
RX330inFL
Sure, but I have always been suspicious of any company that cannot spell Infiniti correct.
They are thinking more Buzz Lightyear and not Nissan.
Old Mar 12, 2013 | 10:49 PM
ho0n's Avatar
ho0n
How would you know that your system is bubble-free? Just go with the "that should do it" approach?
Old Mar 13, 2013 | 07:44 AM
Adamjeeps's Avatar
Adamjeeps
You can see the old fluid transition into the new fluid come out into the drain tube with no bubbles. I have them on 3 vehicles with no problems whatsoever. When you see the new clean fluid, just close the bleeder screw and you are done!
Yes, it looks bad when something is misspelled, but if you do a little research many have used these with no problems.
CChoiVA
RX - 3rd Gen (2010-2015)
Jul 28, 2017 11:33 AM
reisjdmd
RX - 1st Gen (1999-2003)
Mar 1, 2016 10:11 AM
justin1203
Jan 23, 2016 11:15 PM
HYPERBOY
Jun 5, 2007 12:57 PM
johnp
Maintenance
15
Sep 27, 2002 10:49 PM
