Pete60
Old Apr 14, 2011 | 06:43 PM
Pete60's Avatar
Pete60
Default Pete60
Hi Sticky and all,
Have a continuing problem of 3 dasboard lights coming on and staying on all at the same time (check engine, VSC and Traction icons). It started after a Lexus dealership oil change in ABQ a couple of months ago. I have just spent $700 on two repair shop visits with multiple code checks and replacement of oxygen senors Bank #1/ senser #2 and a second visit for Bank #1,sensor#1.
Each time (@$350) was assured that the dashboard 3 icon problem was solved. I got less than 5 miles out of the shop each time before the 3 reappeared at once. Can't go back to this shop and need a new plan for my car (and my wife!)
Live in the Rocky Mts. pretty far from a Lexus dealership so went with a local shop in Durango,Co.
Love my 08 359 RX which I bought used and now has 70K on it. Everything seems to be working and the car is running well without any noticable problems.
Anybody got a suggestion for me? Great thanks Pete60
Old Apr 14, 2011 | 07:02 PM
dcdyd's Avatar
dcdyd
That is terrible. I never had three lights on at the same time. If it is me, I would go to a local auto parts shop and borrow a code reader and try to understand what codes are reported. And go from there.
Old Apr 14, 2011 | 07:23 PM
Pete60's Avatar
Pete60
Default 3 dashboard light icons aall on after $700
Yes, I agree about a new look at the codes after the 2 expensive shop visits. That shop told me to come back yet again and they would run the codes again but I felt I wasn't getten much for my $$$.
Can a novice understand a coder reader if I bought one? Would I be better trying a different shop with a professional instead of myself?
Thanks, Pete
Old Apr 14, 2011 | 07:25 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Pete, most auto parts stores (locally here that would be Advance Auto, Autozone, O'Reilly, etc) have a code reader that they'll come out and hook up to your car for you for free. No need to buy and figure out.
Old Apr 14, 2011 | 07:38 PM
Pete60's Avatar
Pete60
Default Code Reader
Thanks Dave,
We have an AutoZone in Durango, Co. so I might drop in and see if they will have a look. I watched the shop contact the device under the RX dashboard so at least I know where the hookup is.
Any ideas on why the 3 (engine, VSC, traction) icons all come on together and won't go off after a shop spent time reading the codes and replaceing what they said was the problem(s) twice?
Pete60
Old Apr 14, 2011 | 07:44 PM
DaveGS4's Avatar
DaveGS4
Using the forum search tool, came up with these threads that might be useful
https://www.clublexus.com/forums/rx-...-light-on.html
https://www.clublexus.com/forums/rx-...e-driving.html
https://www.clublexus.com/forums/rx-...SC%2C+traction
Old Apr 14, 2011 | 08:16 PM
Rainbird's Avatar
Rainbird
A faulty brake light switch? This seems to be a common problem associated with these dash lights.
Old Apr 14, 2011 | 08:18 PM
RuninRoach's Avatar
RuninRoach
+1 on the faulty brake light switch...it is also something fixed during a recall isn't it?
Old Apr 14, 2011 | 08:40 PM
onedukeof's Avatar
onedukeof
Had the same lights go on, while vacationing in Key West. Replaced brake light switch and everything is fine.
Old Apr 14, 2011 | 08:47 PM
RX330inFL's Avatar
RX330inFL
+1 on the faulty brake light switch as well.
Pete, your local shop is probably not going to know about the brake switch issue. Do you have a Toyota dealership which is closer?
Old Apr 15, 2011 | 05:52 AM
Pete60's Avatar
Pete60
Default Pete60 3 dashboard icons won't go off
Yes, we do have a Toyota dealership in Durango, Co. This just might be the solution to replace the brake light switch.
Thanks All, Pete60
Old Apr 15, 2011 | 08:09 AM
dcdyd's Avatar
dcdyd
Does 08 RX350 has a recall for break light switch? I don't know any recall for 08 RX350.
Old Apr 15, 2011 | 08:53 AM
Adamjeeps's Avatar
Adamjeeps
No recall. If it fails after warranty is up, you are going to pay to have it fixed.
Pete, from now on, come here before you start wasting $$$$$!!!!!!
Old Apr 15, 2011 | 09:16 AM
A1Lexis's Avatar
A1Lexis
BTW if it is a faulty light switch, you can buy the part from Autozone instead of your dealer and save $$
Old Apr 15, 2011 | 06:39 PM
Pete60's Avatar
Pete60
AdamJeeps and all,
Yes, I wish I had looked closer at the Forums before spending $700 for 2 sensors that didn't seem to have any affect on the 3 icons (Check E, VSC & Traction) continuing to stay on.
I think my next move is to AutoZone for a code check and then to the Toyota dealership in Durango, Co. (no Lexus dealers in at least 200 miles out here) for a "Brake Light Switch" replacement. Seems that may be my least costly next move and suggested by many of you as a possible solution.
What a great feeling it is to get so many helpful ideas from all of you. Very proud to be a new member of this Lexus Family Many thanks.
PS to AdamJeeps- my 95 Jeep Laredo with 250,000 miles (and running great) is about to resurface from under the Rocky Mt. winter snow @ 9,300' so I will have a backup till I get my 08 RX 350 cleared up......... Pete
AlexAndUs
Jun 6, 2017 02:28 PM
mpageler
Jun 17, 2016 08:46 PM
JATLIFE
May 1, 2013 07:06 PM
Pivo154
Apr 13, 2012 11:25 AM
scrim67
Oct 27, 2004 08:26 PM
