Speed Sensor replacement in '04 RX 330
Does anyone know how difficult this would be for a mere mortal, like myself. I am by no means a professional mechanic, but I've kept my '66 Ford alive all these years!
wheel speed sensors are pretty straight forward. only trouble might be had while removing them as they tend to get seized in the hole pretty good, but since you are changing it you can easily hammer it out, make sure you have some sand paper handy clean out the hole for the new one.
usually there is onlt a couple bolts holding them on,
Or am I completely off track?
Reviving an oldie here! My abs/trac vsc lights have been on for a while.. Took my car in and the diagnosis is the rear wheel speed sensor. They quoted $580 to replace it! What? He said that the bolt would likely need to be drilled out, but still. Isn't this a $30 part?
Jesterking
Jan 16, 2019 04:57 PM
kldckldc
Aug 25, 2015 06:31 AM
salimshah
RX - 1st Gen (1999-2003)
Jun 2, 2007 09:52 PM
090-5021, 330, abs, club, error code 500, kiwi, lexus, replacement, rx, rx330, sensor, sensors, speed, transmission, wheel
