Changing your battery
Old Sep 25, 2009 | 09:43 PM
p.sabala's Avatar
p.sabala
Default Changing your battery
I had to change the battery in my RX and 1st of all DONT take your car to Lexus to get it changed. They will try and screw you for about 220 dllrs to change it. I bought a battery and changed it, upon changing it I had to reset the power windows. Apperrantly when you disconnect the battery all the window buttons have to be reset, so each window has to be reset by its own button on each door, just roll the window all the way down then alll the way up and hold the button up for about 5 sec. each window must be cycled through and your back in business.
Old Sep 26, 2009 | 04:28 AM
kiwi's Avatar
kiwi
this has already been covered
Old Sep 26, 2009 | 04:41 AM
kitlz's Avatar
kitlz
No, I don't play soccer!
Do take your car to the dealer if the battery is covered under warranty.
Old Sep 27, 2009 | 09:34 AM
mandyfig's Avatar
mandyfig
Guess too late for him-her. kitlz was right, they are covered up to 84 months.
Old Sep 27, 2009 | 10:39 AM
kitlz's Avatar
kitlz
Oh well, expensive lesson learned. 84 month warranty means all 2nd gens are covered for now. Mine was replaced by the dealer at four years, no charge.
Old Sep 27, 2009 | 10:44 AM
salimshah's Avatar
salimshah
25 Year Member
If you have a reasonable justification to have the battery replaced at a non-dealer location, you can talk to your service advisor. But do it sooner than later.
Salim
Old Sep 27, 2009 | 01:25 PM
biff44's Avatar
biff44
Considering all the hassle of resetting everything, why doesn't everyone run a 12V supply to their cigarette lighter while you swap out the battery? Seems like an easy step.
Old Sep 27, 2009 | 03:25 PM
jgr7's Avatar
jgr7
I haven't had to change the battery in my 08 yet but I have used the portable jump starter with the 12v to 12v adapter on both of my Hondas, just plug in and leave key on acc and be careful with the battery leads when you remove them. I put an old leather glove over the pos cable to keep it from going to ground.
Jeff
LovinLexus
GX - 2nd Gen (2010-2023)
Sep 19, 2018 12:31 AM
tarnold
Jan 31, 2014 03:48 PM
lexus114
Jan 31, 2013 07:21 AM
vital
12
Sep 10, 2012 09:18 PM
ecelani
Sep 10, 2010 01:52 PM
