255's on RX400H?
Old Jun 18, 2009 | 07:45 PM
akkeith's Avatar
akkeith
Default 255's on RX400H?
Can anyone tell me if 255's can be run on the RX400H? Will the rub when turned all the way in one direction? What about affect on the warranty? Thanks for any help.
Old Jun 18, 2009 | 08:11 PM
hesham1's Avatar
hesham1
just out of curiousity why do you want to change from the stock width (and aspect ratio)?
Old Jun 19, 2009 | 01:33 AM
akkeith's Avatar
akkeith
I think a taller tire would look better and the width would handler better.
Old Jun 19, 2009 | 01:04 PM
iKon_RX's Avatar
iKon_RX
taller tire wouldn't look better imo. 255s would rub the rear strut with stock wheels, it will not rub in the front. for the rear you need to purchase a 25mm spacer that bolts onto the hub, then you can run 255 tires without rubbing.
Old Jun 19, 2009 | 07:37 PM
tommewin's Avatar
tommewin
There are a few threads regarding this and it has been reported that 255/55/18 will work fine with no issues (rubbing or safety etc). You have way more tire choices in that size. Your speedometer will be slightly off though, although not by much.
jake443
Aug 16, 2019 10:34 AM
Nadim
Apr 10, 2017 04:52 PM
97-SC300
Wheels, Tires & Brakes Forum
Jul 18, 2006 12:33 PM
Shymae
Mar 2, 2004 02:54 PM
EmoDragRacer
16
Jul 15, 2003 02:11 PM
