How Much More ATF I Need ?
04 RX330
After I drain and refill the transmission fluid, run the car 30 minutes, then check the fluid level. It is right between the cold line and the hot line. I am not sure how much more I need to reach the hot line. Thanks for your reply!
Add a 1/4 qt at a time, keep checking till it's right. Make sure you follow the proper procedure in checking the fluid level.
