tapping noise in engine
Old Oct 7, 2008 | 07:11 AM
gsp729's Avatar
gsp729
Question tapping noise in engine
I have a RX350 2007 with less than 18,000 on it.I have a noise in the egine that sound like a value, or value spring that may be broken.
Does anybody have any thoughts what the problem is.
Thanks,
gsp729
Old Oct 7, 2008 | 07:31 AM
lexus114's Avatar
lexus114
Thanks,
gsp729
I`m sure your under warranty,I would make an appointment with the dealer A.S.A.P
Old Oct 7, 2008 | 12:47 PM
The G Man's Avatar
The G Man
How loud is the ticking noise?
Old Oct 7, 2008 | 01:21 PM
xfirechief's Avatar
xfirechief
What is a egine?? If u mean engine do u think it could be the injectors.
Old Oct 8, 2008 | 07:10 AM
lexus114's Avatar
lexus114
Thanks,
gsp729
If it sounds like a valve spring may be broken,you better get it checked out.But that would be much more than a ticking sound.
Old Oct 16, 2008 | 06:58 PM
Azul's Avatar
Azul
Default Engine tapping noise
I don't know if you have resolved this or not but there is a seventh injector that is used at start up to enrich the mixture until the engine is warmed up. You can hear this injector at start up. I called the dealer ship on this and he knew right what I was taking about.
Good luck with your issue.
Azul
Old Oct 16, 2008 | 07:16 PM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
I'm having the same problem here...but my car is old, let us now how the dealership will handle this
Old Oct 17, 2008 | 06:19 AM
lexus114's Avatar
lexus114
Azul
A seventh injector? wow.I wonder how that works
Old Oct 17, 2008 | 09:00 AM
LEP XEP's Avatar
LEP XEP
I just bought the 07 RX350 and noticed that tapping noise too (sound like the valve). I called the dealer and the head tech said use Premium Gas in next couple fill up to see if it's go away. If not, I have to bring it in for them to check it out.
Old Oct 30, 2008 | 08:10 AM
CarNutTO's Avatar
CarNutTO
Any updates on this issue?
Old Oct 30, 2008 | 08:23 AM
mandyfig's Avatar
mandyfig
My 04 had a TSB for injector ticking noise, got it done and now it's gone.
Old Oct 31, 2008 | 09:54 AM
LEP XEP's Avatar
LEP XEP
Just dropped the RX off the dealer ship this morning. I told the rep it has a lound tapping noise when cold start (sound disel engine) and he told me they will check it out. He said he kinda knew the problem. We'll see how it'll goes. I also got the passenger outside molding comes loose too.
Do we have to tell them this is the warranty work or they already know it should be under warranty? I got CPO with 3 years 100k miles warranty.
Thanks guy.
Old Mar 7, 2011 | 04:22 PM
JamesHuang's Avatar
JamesHuang
My wife's '04 RX330 started making a ticking noise. Well outside the warranty period so will have to check out that TSB.
Does anyone have a pdf on that TSB by chance?
Old Mar 9, 2011 | 09:54 AM
Bluesjam's Avatar
Bluesjam
They know what the problem is, it's piston slap. Mine has is bad. Just Google "Lexus piston slap". There's a couple of days worth of reading there. I just can't understand why they made a motor and didn't have the clearance of cylinder and piston OD correct.
Old Mar 9, 2011 | 10:00 AM
tomit's Avatar
tomit
May be carbon buildup - try a can of BG 44K in a full gas tank.
