Electrical Gremlins or Usual Problems?
1. The driver window control unit sometimes works for putting all of the windows down. Dealer replaced one of the switches and now they all work, however the drivers window won't work on the auto feature.
2. The drivers side mirror sometimes will toggle side to side, but sometimes won't. Dealer has "fixed" it twice, but still is intermittent.
3. The sunroof won't open or close automatically. My GS300 always did. Also, if I close the sunroof after it has been on tilt, it will close but if I hold it too long, it will just re-tilt open. If the sunroof is open and I close it and hold it too long, it will close and then go into the tilt feature.
The dealer gave me some line about there being resets on the windows and mirror and not to worry about it. If they are resetting themselves, I'd like to know why.
Any thoughts other than finding another dealer? The next closest dealer is 2 hours away and I don't have that kind of time to take off from work. Thanks.
If that is not possible and you have to deal with these bozos, then I would suggest call the service manager and tell him that their tech has not been able to fix the problems. You would be bringing the vehicle back and park it with them till they fix the problem, while you put miles on their loaner.
Maybe this time they will put a better tech or by luck replace the right piece.
Make sure you get this fixed under warranty.
Salim
For the other problems sounds like they still need fixing.
