Need help on removing the head light
Just bought a 08 AWD RX350. Trying to swap out the oem hid to 6000k d2s. Here is the problem, the cap is so tight that I am unable to remove it unless I remove the headlight. Does anyone have an instruction on how to remove the headlights?
Thanks for the help.
It's not easy to get the headlight out. You've got to take the bumper cover loose then put some tape down on it so you don't scratch it up.
I'd take it to the dealer and have them put the new bulbs in for you. That way if it doesn't get sealed properly and you get moisture in the housing they'll replace it under warentee with no questions asked.
If you really do want step by step instructions pm me.
jimmykiss
Mar 3, 2013 11:18 AM
Och
Mar 8, 2009 04:25 PM
