Fuel filter replacement??
Old Nov 4, 2007 | 10:53 AM
Lextranny's Avatar
Lextranny
Default Fuel filter replacement??
How often you supposed to replaced the fuel filter? Dealer says never.
True or false?
I got a 2005 RX330 AWD with 35k miles on it.
Has anyone done it?
Old Nov 4, 2007 | 01:00 PM
Lexmex's Avatar
Lexmex
On U.S. gas, probably you can go a very long time and not need changing. U.S. gas is of sufficiently high quality that for the average time of ownership of most vehicles, it is not necessary.
HOWEVER, having lived where I live and having to use Pemex gas (no other stations down here), I have had it changed several years ago (and it could use another changing), as the last time they did it, I did have a sufficient amount of accumulation. My uncle down here has changed out several fuel filters on vehicles and probably in the coming year will change it out with him again.
Old Nov 4, 2007 | 08:50 PM
andreys's Avatar
andreys
True or false?
Has anyone done it?
According to Lexus/Toyota, you should never need to change the filter, so dealer is perfectly right. However, from experience, it is a good idea to replace the filter after about 100k or so.
-- Andrey
Old Nov 7, 2007 | 11:08 PM
Lextranny's Avatar
Lextranny
Thanks for the info......how hard is it to DIY? I was told the fuel filter is inside the gas tank?
Old Nov 8, 2007 | 07:25 AM
Lexmex's Avatar
Lexmex
Well, at least on the RX300, one has to remove the rear left seat and there is a kind of panel one can access the pump and the filter attached on to it. However, it is not something I would do my own as you have to take some precautions and disconnect some lines.
Old Nov 8, 2007 | 07:45 AM
andreys's Avatar
andreys
Fuel filter is very easy to change if you're comfortable with tools. Fuel filter is located just behind the driver's door (underneath) and has one fuel line going in, and one fuel line going out. You disconnect them, swap the filter and you're done.
However, if there is nothing wrong with your filter, there is absolutely no need to change it.
Old Nov 8, 2007 | 07:48 AM
andreys's Avatar
andreys
are you sure? I have never seen a vehicle where fuel filter is located *inside* the car and fuel filter swap requires seat removal. Even on my sister's Highlander (same as your RX300) fuel filter is underneath the car and no seat removal is required. Are you confusing fuel filter with something else?
Old Nov 8, 2007 | 08:10 AM
Lexmex's Avatar
Lexmex
After removing the seat and carpet, there is something called a Floor Service Hole Cover and that goes to the fuel tank where the pump and the filter are. The fuel filter surround the fuel pump. Not sure about the other configurations of vehicles you mentioned. Now, I could fathom you could get at that tank without doing that, but I can't see much separation of space there. A few years back when I had this done at Lexus they indeed had removed the seat to get at it.
Old Nov 8, 2007 | 08:36 AM
andreys's Avatar
andreys
wow... I just looked at Lexus FSM and indeed, fuel filter is inside the fuel pump next to the gas tank. That's just stupid... So yeah, doing that in person is possible, but is certainly more inolved than on other vehicles.
Best advise, if things work and you have no problems with fuel delivery, no need to change the filter.
Old Nov 8, 2007 | 08:44 AM
andreys's Avatar
andreys
Here is FSM for those who're interested
File Type: pdf
Old Nov 8, 2007 | 08:57 AM
Lexmex's Avatar
Lexmex
I may do a DIY on this with my RX300, but only at the point when I am ready to leave Mexico (also may change out my catalytic converter again (already on my second aftermarket cat down here).
I figure one might be able to the tip the gas tank down to get at it without the seat, but I do know of vehicles my uncle as worked on where the filter is in other more convenient locations. I agree with you, the location is stupid, major PITA.
Old Nov 8, 2007 | 09:06 AM
andreys's Avatar
andreys
Default warning: pic
Here is the location for a fuel filter on my 4Runner... Basically it is located just underneath the skid plate sort of on the side of a body and is *very* easy to swap with just two bolts that I was talking about earlier:
Old Nov 8, 2007 | 09:11 AM
Lexmex's Avatar
Lexmex
Here's the one for the RX300, (photo originally came from RX300 owner and CL member meetya).
The fuel pump is enclosed by this filter.
Old Nov 8, 2007 | 11:47 AM
Lextranny's Avatar
Lextranny
Sounds like it requires a lot of work just to change it. I'll have to think about it.
Old Feb 5, 2021 | 09:49 AM
Miketup's Avatar
Miketup
Default Where is the fuel filter?
-- Andrey
I am wondering where the filter is located on a RX 450h?
Mine has 124k miles
desantura
RX - 1st Gen (1999-2003)
37
May 3, 2017 05:39 PM
shikbas
May 28, 2009 07:29 AM
last993
Nov 30, 2003 05:16 PM
fallabel
Jul 8, 2003 09:12 PM
gebo
Sep 11, 2002 12:14 AM
