Bluetooth...have to register it everytime
Hi~
This is my first post...
My problem is that everytime I start the car I have to register my bluetooth connection. It used to be automatic once I registered my cell but after I had my first oil change at Lexus, I have to renew it everytime I start my car.
Is this something I can do from the NAV screen or setting or should I take this to Lexus and let them have a look?
It's just weird that it's not working after an oil change.
Best,
Jack
Best,
Jack
I'm sure someone will chime in with more exact info...or I can if you can wait until I go out to the parking lot at lunchtime
...but I believe there's an 'autoconnect' setting on the deck. This is possibly not set correctly ...Seems like the most logical solution to the problem, particularly since the system worked fine prior to the oil change.
On your NAV hit the Info Button, then the Phone Icon, then the Settings Icon near the bottom left, then right below the Bluetooth Icon at the top right there's an "Auto Connect" icon that needs to be lit/enabled...
Jim
Jim
Lohus
May 19, 2009 11:15 AM
