Octane
Old May 19, 2007 | 06:11 PM
  #46
TunedRX300's Avatar
TunedRX300
Originally Posted by RXOwner
Speaking of 87 octane and clogging your fuel injectors, what are the thoughts on the fuel-injector cleaners? I'm referring to the liquid stuff in a bottle that you pour in your tank (e.g. STP?)
In other words, if I use this "dirty" octane (as many like to think of it), why can't I pour a bottle of that cleaner in on every other fill-up?
Be very careful with additives, you want to get the good stuff (PEA). I recommend Gumout Regane Complete Fuel System Cleaner. MSDS showed 30-40% PEA. Go to http://www.pennzoil-quakerstate.com/...l7_msds_fs.htm to check it out.
In case you have not noticed, Gumout is now owned by SOPUS, same company that makes Shell V Power gasoline.
Most gas treatment and fuel injector additives have low % of key carbon deposit removal additives. Quality not quantity in this case.
Old May 19, 2007 | 10:00 PM
  #47
NXOwner's Avatar
NXOwner
From: Driving a UX Hybrid F-Sport! (in So California)
I guess find out how much a bottle of that stuff is and do the math--a bottle on every other fill-up, or pay for premium fuel on every fill-up.
Old May 19, 2007 | 11:03 PM
  #48
AM1's Avatar
AM1
CL Folding 100,000
...and, by the time the 87 octane clogs my fuel-injectors to the point of noticiable impact (if, in fact, they really do), I would have traded the car in already.
same here. car will be returned b4 anything goes wrong.
Old May 20, 2007 | 08:43 AM
  #49
jfelbab's Avatar
jfelbab
The premium blend is almost universally 20 cents a gallon more than the 87 octane around here. A typical fill is about 15 gallons so the price differential of premium over regular is $3.00 a tankfull. Fuel injector cleaner runs $3.50 to $5.00.
Old May 20, 2007 | 07:19 PM
  #50
mandyfig's Avatar
mandyfig
The Injector Cleaner is recommended every 3~5 thousand miles. Not every fill up. Looks like every 10 fill ups?
Old May 20, 2007 | 10:55 PM
  #51
NXOwner's Avatar
NXOwner
Interesting. However, if what "mandyfig" says is correct (use the cleaner every 3,000 to 5,000 miles), then the "87 octane/FI Cleaner" method is more cost efficient as long as that grade of gasoline doesn't noticeably affect performance.
Old May 21, 2007 | 07:29 AM
  #52
jfelbab's Avatar
jfelbab
I'd probably use 87 octane as well if it didn't make my car smell like rotten eggs. The Lexus dealer checked the tune and found it to be in spec. They said that I need to burn better gas. When I do the smell goes away. The dealer suggests that continued burning the cheap gas in my car will damage the cat.
Anyone else have this same issue with smell from the cheaper gas?
Well $3.00 a tank is no big deal so I just run premium. I'll likely buy an 09 when they come out so its not a problem.
Old May 21, 2007 | 12:01 PM
  #53
AM1's Avatar
AM1
CL Folding 100,000
never happened to me b4.
Old May 21, 2007 | 06:56 PM
  #54
mandyfig's Avatar
mandyfig
I have heard lexmex say the same thing but he's in Mexico....but I doubt it that 87 makes the car smell....
Old May 21, 2007 | 07:25 PM
  #55
jfelbab's Avatar
jfelbab
I can assure you that when I burn 87 the car smells of rotten eggs and when I burn premium it doesn't. I've played around with this for a long time (since November of 04) and that is what occurs, repeatable 100%. I've had my dealer look at this three times and each time he stated the car is properly tuned and to just burn better gas.
So what to you think is causing the smell?
Old May 21, 2007 | 07:29 PM
  #56
mandyfig's Avatar
mandyfig
Anybody willing to experiment or confirm this?
Old May 22, 2007 | 12:10 AM
  #57
AM1's Avatar
AM1
CL Folding 100,000
i've been putting 87 into my rx330 eveer since ive had it. ive put in all brands and it never smells like that. sounds like BS from the dealer.
Old May 22, 2007 | 06:19 AM
  #58
The G Man's Avatar
The G Man
Isnt there a TSB for the sulfer smell?
Old May 22, 2007 | 06:38 AM
  #59
jfelbab's Avatar
jfelbab
[Head snaps to attention] ...TSB? There may be a TSB on this???
roxy208
33
Dec 7, 2014 07:52 PM
RegularGal
Chicago Lexus Club
Nov 20, 2014 02:15 PM
jclem
13
Jul 28, 2012 07:22 PM
VELLANOLEX
CL of Southern California
34
Apr 8, 2009 01:24 PM
Woogie
Apr 20, 2005 09:19 PM
