Maintenance Light....
Old Oct 13, 2004 | 12:23 PM
C21Lexus's Avatar
C21Lexus
Question Maintenance Light....
The maintenance light is on in my 2004 RX 330. I looked at the maintenance section of my Nav, and the "Oil" and "tires" are highlighted. I have 7600 miles on it. Checked the oil-its fine, last changed at 5250 miles. Checked the tires and they are all around 33lbs psi.
Any suggestions?
Old Oct 13, 2004 | 12:59 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
This should help you:
https://www.clublexus.com/forums/sho...intenance+reqd
Old Oct 13, 2004 | 02:23 PM
clexusking's Avatar
clexusking
The maintenance light which illuminates in the instrument cluster comes on based on the mileage since the last reset. The reminders in the navigation system are user set and come on at the user defined intervals.
Old Oct 14, 2004 | 03:27 PM
C21Lexus's Avatar
C21Lexus
Hey clexusking,
You mentioned that the light comes on "based on the miles since the last reset....". Was the dealer supposed to reset this when I had my 5K service. Did it happen (factory default) once I hit 7500 miles?
Just curious.
Thanks,
Jeff
Old Oct 15, 2004 | 07:07 AM
clexusking's Avatar
clexusking
Yep, the dealer is supposed to reset the light at each service. Resetting it is a simple procedure and does not require a return trip to the dealer.
FrOHiKE
Feb 23, 2016 05:55 PM
igo2xses
Oct 16, 2008 11:47 PM
edman688
Jun 26, 2007 10:43 AM
darkalley
Feb 21, 2006 11:45 PM
reamemiya
Maintenance
Jan 31, 2006 07:52 PM
