Weird problem
Old Mar 4, 2004 | 05:10 PM
scargo's Avatar
scargo
Default Weird problem
OK, does anyone know what this could be? My RX300 is terrific, but every now and then strange things happen with the electrical system. For example, started the car and found the "Outside Temp" reading was in Celcius instead of Fahrenheit! Restarted the car and now the reading is back in Fahrenheit again. Another thing -- some of the radio presets occasionally disappear. Any suggestions?
Old Mar 4, 2004 | 07:06 PM
nyca's Avatar
nyca
loose battery cable, or a loose supply connection at the main fuse panel.
Old Mar 5, 2004 | 06:15 PM
kRonX's Avatar
kRonX
ya sounds like a lose connection to the battery. But if it persists take it to the dealer.
Old Mar 8, 2004 | 12:47 PM
ederny's Avatar
ederny
Yup, known probblem...
Let's see, a RX300, 2002 so the battery is now 2+ years old, starting the car in cold old NY during the winter....
Have the battery tested and see if it is still capable of full output cold cranking amps (CCA). The circuits in the 300 are very sensitive to low voltage on cranking and then reset if the voltage is too low even for an instant. The clock is the big offender here.
Let us know what you find...
Old Mar 10, 2004 | 02:13 PM
scargo's Avatar
scargo
Thanks so much -- I will ask my Lexus guys to look at the battery. Will let you know what they say....
DaveInMesa
RX - 1st Gen (1999-2003)
May 7, 2016 08:48 AM
DavidinCT
Mar 19, 2010 08:03 PM
pinoyballa
Feb 12, 2009 12:59 PM
RHS
Mar 18, 2006 11:06 PM
renn1
Oct 23, 2005 11:36 PM
