Window Reset Issue
Old Jun 15, 2024 | 04:21 PM
OldRXGuy's Avatar
OldRXGuy
Default Window Reset Issue
Since I had misspelled "Reset" the previous thread wasn't getting much response. Let me try again.
I need some advice from the experts. 2004 RX330.
I had a battery issue recently and needed to reset the window controls.
Went through the instructions like always, but it didn't reset. So, I started over and the window wouldn't go all the way down. Turned the car off and back on and it went down but wouldn't come up. Turned the car off, then back on and it went up a bit. Repeated that until it was all the way up.
Thinking the battery is a problem, started the car and went around the block a couple of times. Came back to the garage and the same thing happened. It would stop after a second or two, do the car off/on and it would move a bit again. Finally got it all the way up again.
Makes me think it's not the battery. It went through all of the reset paces the first time; it just didn't reset. Maybe the control module is confused?
I’m wondering if disconnecting the battery, reconnecting it will reset the control module?
A bad module?
Any advice is appreciated.
Old Jun 16, 2024 | 11:30 AM
OldRXGuy's Avatar
OldRXGuy
Ok, I'm an idiot.
The process works well IF you don't try to reset the driver's door...
Old Jun 17, 2024 | 10:09 AM
cfh13427's Avatar
cfh13427
A bad module?
I Don't know if this will Help, but I thought I'd pass it along, Best of Luck!
OldRXGuy
Jun 15, 2024 01:36 PM
allicedout
Apr 7, 2014 11:48 AM
p.sabala
Sep 27, 2009 03:25 PM
Sgt_K
Apr 10, 2008 11:28 AM
momoko
Oct 9, 2006 12:48 PM
