Parking brake hardware
Old Jun 11, 2024 | 08:48 PM
edd16's Avatar
edd16
9th Gear
Default Parking brake hardware
Hello,
Did any one replaced the parking brake hardware, specifically the pins on an AWD?
Got my rx350 2009 awd without the parking brake installed. I guess the old owner had it stuck and decided to just remove the parking brake. I dont like relying on the transmission parking pawl lock and want to put the parking shoes back for some time now, and I wonder if I need to remove the wheel bearing hub to be able to have the pins in from behind, especially the one shaped like a U. This will make the job not as easy as I like it to be since I'll have to basically do a wheel bearing job + a parking brake job.
Thanks
Old Jun 11, 2024 | 09:47 PM
Leeper's Avatar
Leeper
Originally Posted by edd16
Hello,
Thanks
The only time I use my parking brake is when jacking up my car otherwise it is never engaged
Old Jun 12, 2024 | 05:09 AM
edd16's Avatar
edd16
9th Gear
you just put it to park even when you park on a hill? I think too much pressure on the parking pawl can damage it, but I've never heard of one fail.
Old Jun 12, 2024 | 07:59 AM
Leeper's Avatar
Leeper
Yes, just put it in park even on a hill, I've never heard of any car breaking/rolling. I've found many times where I've forgetten to disengage the parking brake for a little bit but never heard of a failure so the only time parking brake is used is when jackng up my car
Old Jun 23, 2024 | 03:15 PM
Felix's Avatar
Felix
Removing the rotor will show you. You shouldn't need to remove the hub to install/replace the parking shoes as they sit on the outside of the hub & on the backing plate. I'm one that wants a parking brake whether it is parking shoes or caliper activation.....
Old Jun 23, 2024 | 07:55 PM
edd16's Avatar
edd16
9th Gear
I found mine with not hardware, so I can't just change the shoes. I did try to get the U shaped pin when I installed rotors but I couldn't get it from behind, unless there is a special technique, my guess is I need to take the hub out.... Unless someone already got the job done and can share the technique to get U pin completely inside.
NoobExe
Apr 4, 2022 01:16 AM
aeroelasti
Apr 3, 2022 11:02 AM
Alphaman19
Jun 23, 2014 11:39 AM
LexaGlide
Jan 15, 2013 03:46 PM
nighthawk
Suspension and Brakes
Jul 31, 2011 04:13 PM
