Replace Splash shield clips
Old Mar 29, 2024 | 07:25 PM
kaylamf05's Avatar
kaylamf05
9th Gear
Default Replace Splash shield clips
Recently, had the front, center, and rear splash shields taken off of my 2005 Lexus RX330, in order to, spray the undercarriage. However, the retainer clips/silencers broke, and I've been trying to find a good site to get replacements. Not trying to pay dealer prices for something like this. I've been looking through amazon and ebay, but not sure if the sizes are correct and how many of each I would need....
Old Apr 3, 2024 | 02:50 PM
Felix's Avatar
Felix
The two front under car sheilding is held on by bolts (front one) & the rear behind the front is held on w/ sheet metal screws using inserts.
Old Apr 3, 2024 | 03:16 PM
Leeper's Avatar
Leeper
I just picked up mine at "Pick-a-part" (salvage yard) these are the same on the RX330 and RX350
Old Apr 3, 2024 | 03:49 PM
MattRX's Avatar
MattRX
These clips can also be found on the 2006-2007 Highlander hybrid, 2011+ Sienna, 2010+ RX and 11+ Highlander
I could not find a knockoff of the two subframe clips that use a screw, so I ordered some 51453-48010 / 51453-0E010 knockoffs to try instead
Old Apr 27, 2024 | 12:24 PM
kaylamf05's Avatar
kaylamf05
9th Gear
Thanks. I will try this
Old Apr 27, 2024 | 01:09 PM
MattRX's Avatar
MattRX
I just received the clips recently and can confirm they won't work without drilling out the splash shield's hole larger.
If you have a 3D printer, you can print these recreations of them I made
LazE
Sep 7, 2022 05:32 PM
easterr
Aug 10, 2015 07:28 AM
minato
Canada
12
Nov 5, 2012 07:48 AM
VictorGX
GX - 1st Gen (2003-2009)
13
Jan 21, 2012 04:27 PM
