ABS/BRAKE/VSC/(!) Message
All, I have a 2008 RX 400h with roughly 120k miles. Yesterday, I was driving downhill and i noticed that my brake was pulsating when I pressed on the brakes. The pulsating never happened on a flat road yesterday; however, this morning, while driving on a normal road my ABS/Brake/skidding and (!) lights came on and a few minutes later the VSC message showed up as well. What could be the problem? Appreciate all your help. Thanks in advance.
While driving downhill on a grade > 9.12218 degrees this will case a pulsating brake pedal and later a dash warning light.
Did you scan for codes?
If only when downhill I would first suspect a slightly "warped" rotor since it only appears on more aggressive braking but the warning lights in dash suggest there is problems in the ABS controlled braking system or it sensed a condition it didn't like.
Suscribed to find out what the problem is.
Spoiler
I just used my actron OBD II pocket scanner and found 0 codes with a down arrow. MIL OFF, MONITRS, 0 Inc, 7 Ready, Misfire, Fuel, Comp, Catlyst, Evap, 02 Snsr, 02 Htr
The lights and the VSC message is still on
If you are going to keep this car and continue driving in mountains, I would recommend upgrading the brakes to 3rd Gen RX (https://www.clublexus.com/forums/rx-...e-upgrade.html)
PS: Don't forget to use B "gear" while driving downhill (engine brake)
Pajabon
GX - 1st Gen (2003-2009)
Apr 5, 2022 01:38 PM
BossSc430
Aug 21, 2019 11:53 PM
pcfall
Dec 23, 2013 05:26 PM
